on the weekend i made a fresh install of openhabian image 1.4. Everything is running fine, but in the log i found the exceptions shown below. every 5 minutes six of them.
and yes, everything is up and running. no further problems seen.
2018-01-07 20:05:00.166 [ERROR] [ematic.handler.HomematicThingHandler] - java.lang.String cannot be cast to java.util.Map
java.lang.ClassCastException: java.lang.String cannot be cast to java.util.Map
at org.openhab.binding.homematic.internal.communicator.parser.GetParamsetParser.parse(GetParamsetParser.java:40) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setChannelDatapointValues(RpcClient.java:182) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.setChannelDatapointValues(AbstractHomematicGateway.java:477) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.setChannelDatapointValues(CcuGateway.java:118) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadChannelValues(AbstractHomematicGateway.java:458) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.handler.HomematicThingHandler.loadHomematicChannelValues(HomematicThingHandler.java:268) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.handler.HomematicThingHandler.access$1(HomematicThingHandler.java:262) [222:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.handler.HomematicThingHandler$1.run(HomematicThingHandler.java:76) [222:org.openhab.binding.homematic:2.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
any idea?
