- Platform information:
- Hardware: Raspberry Pi 4 Mobel B
- OS: openHabian (Raspbian 10 (buster))
- Java Runtime Environment:
- openHAB version: 3.1.0
- Issue of the topic: Homematic 4-channel actuator HM-LC-Sw4-DR provides only one single STATE (including other attributes) instead of four. The actuator is bindes via Homegear as well as different other stuff that works properly so far.
The one channel / STATE that is actuatlly added corresponds obviously to the first channel of the actuator only. Which can be properly controller and reports feedback.
It seems there’s no way to add further channel manually, so I’m pretty much lost at the moment unfortunately.
I saw, that i the channels the number before the “#STATE” seems to represent the channel number, e.g. in “homematic:HG-HM-LC-Sw4-DR:734f822930:OEQ0045288:1#STATE (Switch)”.
So I’d just need to have the same thing with 2, 3, and 4#STATE.
Many thanks in advance!
