Homematic IP BS2 double switch
Hi @ all and merry christmas. Got an Homematic switch. Now I’m trying to include it in my openhab4 but wondering about the right channel description. I tryied:
    Thing HMIP-BS2     #############      "Schalter"    @    "Wohnzimmer" {
        Channels:
            Type HMIP-BS2_1_STATE : 1#STATE [
                delay = 0,
                receiveDelay = 0
            Type HMIP-BS2_2_STATE : 2#STATE [
                delay = 0,
                receiveDelay = 0
    }e
But the log says:
11:57:17.996 [ERROR] [l.thing.internal.GenericThingProvider] - Channel type homematic:HMIP-BS2_1 could not be resolved.
11:57:18.001 [ERROR] [l.thing.internal.GenericThingProvider] - Channel type homematic:HMIP-BS2_2_STATE could not be resolved.
11:57:18.040 [WARN ] [nternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
11:57:18.066 [WARN ] [nternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
11:57:18.145 [WARN ] [nternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
11:57:18.403 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
11:57:18.407 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
11:57:18.418 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
11:57:18.422 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
11:57:18.437 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
11:57:18.443 [WARN ] [.core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'homematic:HMIP-BS2:ccu2:003160C999B46F' because the thing type was not found in registry.
The Basic UI recognizes it as online.
I would be extremely grateful for any tips
Update: After a bit of trial and error, I found out that channels 4 and 8 are the right ones. For whatever reason.
The rigth channel desribtion:
        Channels:
            Type HmIP-BS2_4_STATE : 4#STATE [
                delay = 0,
                receiveDelay = 0
            Type HmIP-BS2_8_STATE : 8#STATE [
                delay = 0,
                receiveDelay = 0
Cheers!
