Hello everybody,
I have the problem that the trigger “LONG_PRES_RELEAS” is not fired with my Homatic Binding.
The “PRESS_LONG” and “PRESS_SHORT” triggers come through.
I wanted to use it to implement a roller blind control.
As long as the button is pressed, the roller blind should move and after releasing the button it should stop.
I can guess that this trigger still exists in earlier versions. Has it been removed?
My setup:
openhabHAB 2.5.9 (Esxi)
Raspimatic(CCU) 3.53.30.20200919
HMIp Button WRC6
thanks in advance
