I tried to get a HmIP-BSL work with openhab 2.3
The item can be added (it is shown as “no description (HmIP-BSL)”.
Then I created a thing and item for state. Switching the actor changed the state-item from OFF to ON or from ON to OFF. Now I wanted to control the actor via openhab. The actor does not react. The log tells me Datapoint is readOnly, it is not published to the gateway with id ‘xxxxx’: ‘xxxxxx:3#STATE’
Is this actor not supported or not controllable via openhab2? Is there something I’m doing wrong?
according to the documentation of this device has several STATE data points in different channels. The STATE datapoint of channel 0 (Maintenance) is a read-only data point.
If you the want to control the switch from openHAB you can use PRESS_LONG or PRESS_SHORT.
