Hi!
I am using Openhab with Alexa (via Cloud connector) and I am using Homematic IP for multiple temperature/humidity sensors.
We have two Alexa accounts (mainly because of two different spotify accounts for my wife and me).
The weird behaviour: via Alexa, with my account I can ask for temperature or humidity of a room. In my wifes account, we can ask for temperature but asking for humidity only works from time to time.
Any idea what could be the reason? We did add/remove all things in alexa multiple times for both accounts.
Group ThermostatBadOG1 "Bad" {alexa="Endpoint.Thermostat"}
Switch ThermostatBadOG1_BatteryStatus "Thermostat Bad OG1 Batterie [%s]" (Maintenance) {channel="homematic:HmIP-STH:ccu:000E5BE993FB68:0#LOW_BAT" }
Number ThermostatBadOG1_TempSet "Thermostat Bad OG1 Temperatur Set [%.1f°C]" {channel="homematic:HmIP-STH:ccu:000E5BE993FB68:1#SET_POINT_TEMPERATURE" }
Number ThermostatBadOG1_TempAct "Thermostat Bad OG1 Temperatur Act [%.1f°C]" <temperature> (OG_Bad, ThermostatBadOG1) {alexa="TemperatureSensor.temperature", channel="homematic:HmIP-STH:ccu:000E5BE993FB68:1#ACTUAL_TEMPERATURE" }
Number ThermostatBadOG1_Luftfeuchte "Thermostat Bad OG1 Luftfeuchte [%.0f %%]" <humidity> (OG_Bad, ThermostatBadOG1) {alexa="CurrentHumidity", channel="homematic:HmIP-STH:ccu:000E5BE993FB68:1#HUMIDITY" }
