Hello Everyone,
I have java errors in my OH 3.3 setup in connection with my Homematic Binding. Maybe you have an idea what this can be. Actually I would have thought that so far I have configured the Binding and the Things correctly.
Excerpt Openhab.log
2022-12-30 05:36:36.103 [WARN ] [nicator.server.BinRpcResponseHandler] - Software caused connection abort: recv failed
java.net.SocketException: Software caused connection abort: recv failed
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:115) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:168) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.message.BinRpcMessage.<init>(BinRpcMessage.java:78) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.server.BinRpcResponseHandler.run(BinRpcResponseHandler.java:52) [bundleFile:?]
2022-12-30 05:37:37.255 [WARN ] [nicator.server.BinRpcResponseHandler] - Connection reset
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:186) ~[?:?]
Excerpt from the Homematic.things
Bridge homematic:bridge:CCU2 "eQ3-HmIP-CCU3-App - dehs-s05.xxxxx.local" @ "GATEWAY-CCU3" [ gatewayAddress="dehs-s05.xxxxx.local", callbackHost="192.168.3.32" ]
//Heizung//
Thing HM-CC-RT-DN OEQ1258288 "Küche Heizung" @ "Küche"
Thing HM-CC-RT-DN OEQ1258320 "Esszimmer Heizung" @ "Esszimmer"
Thing HM-CC-RT-DN OEQ1256766 "Wohnzimmer Heizung" @ "Wohnzimmer"
Thing HM-CC-RT-DN OEQ1258747 "Badezimmer EG Heizung" @ "Badezimmer EG"
Thing HM-CC-RT-DN OEQ1256788 "Flur EG Heizung" @ "Flur EG"
Thing HM-CC-RT-DN OEQ1256764 "Kinderzimmer 1 Heizung" @ "Kinderzimmer 1"
Thing HM-CC-RT-DN OEQ1259181 "Schlafzimmer Heizung" @ "Schlafzimmer"
Thing HM-CC-RT-DN OEQ1256489 "Büro Heizung " @ "Büro"
Thing HM-TC-IT-WM-W-EU OEQ0697950 "Büro Wandthermostat" @ "Büro"
Thing HM-CC-RT-DN NEQ1402007 "Bad Handtuchheizung" @ "Badezimmer OG"
Thing HmIP-BWTH 000C9A49A310E4 "Bad Fußbodenheizung" @ "Badezimmer OG"
//Sensoren//
Thing HMW-Sen-SC-12-DR OEQ0107439 "Fenster OG Sensoren" @ "Fenster Sensoren"
Thing HMW-Sen-SC-12-DR OEQ0863373 "Fenster EG Sensoren" @ "Fenster Sensoren"
Thing HMW-Sen-SC-12-DR OEQ0863533 "Fenster EG/OG Sensoren" @ "Fenster Sensoren"
//Rauchmelder//
Thing HMW-Sen-SC-12-DR OEQ0863534 "EG/OG Rauchmelder" @ "Rauchmelder Sensoren"
Thing HM-Sec-SD-2 OEQ0600063 "Vorratsraum Keller" @ "Rauchmelder Sensoren"
Thing HM-Sec-SD-2 OEQ0599588 "Waschkeller" @ "Rauchmelder Sensoren"
Thing HM-Sec-SD-2 OEQ0748897 "HAR Keller" @ "Rauchmelder Sensoren"
//Rollladen//
Thing HMW-LC-Bl1-DR OEQ0281557 "Küche Rollo" @ "Küche"
Thing HMW-LC-Bl1-DR OEQ0281365 "Esszimmer Rollo" @ "Esszimmer"
Thing HMW-LC-Bl1-DR OEQ0281403 "Wohnzimmer Rollo" @ "Wohnzimmer"
Thing HMW-LC-Bl1-DR NEQ1827104 "Badezimmer EG Rollo" @ "Badezimmer EG"
Thing HMW-LC-Bl1-DR OEQ0281408 "Flur OG Rollo" @ "Flur OG"
Thing HMW-LC-Bl1-DR OEQ0280950 "Kinderzimmer 1 Rollo" @ "Kinderzimmer 1"
Thing HMW-LC-Bl1-DR OEQ0281363 "Schlafzimmer Rollo" @ "Schlafzimmer"
Thing HMW-LC-Bl1-DR OEQ0281548 "Büro Rollo" @ "Büro"
Thing HMW-LC-Bl1-DR OEQ0281359 "Badezimmer OG Links Rollo" @ "Badezimmer OG"
Thing HMW-LC-Bl1-DR OEQ0281390 "Badezimmer OG Rechts Rollo" @ "Badezimmer OG"
//Digital-In-/Output - Relaisausgang//
Thing HMW-IO-12-Sw14-DR NEQ0906824 "Digit InOut 1" @ "Other"
Thing HMW-IO-12-Sw14-DR OEQ1530189 "Digit InOut 2" @ "Other"
Thing HMW-IO-12-Sw14-DR OEQ1530251 "Digit InOut 3" @ "Other"
//Analog In-/Output//
Thing HMW-IO-12-Sw7-DR OEQ0161335 "Schaltaktor EG / Taster Universal (1)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161499 "Schaltaktor EG / Taster Universal (2)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161728 "Schaltaktor EG / Taster Universal (3)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161495 "Schaltaktor OG / Taster Universal (1)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161561 "Schaltaktor OG / Taster Universal (2)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161653 "Schaltaktor OG / Taster Universal (3)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161513 "Schaltaktor Outdoor / Taster Universal (1)" @ "Other"
Thing HM-LC-Sw2-FM QEQ1490893 "Schaltaktor Outdoor / Taster Universal (2)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161405 "Schaltaktor Outdoor / Taster Universal (3)" @ "Other"
Thing HMW-IO-12-Sw7-DR OEQ0161398 "Schaltaktor Outdoor / Taster Universal (4)" @ "Other"
//Sonstiges//
Thing HmIP-STHO 000ED8A9A28248 "Terrasse Temperatur-Luftfeuchtigkeit" @ "Temp Sensoren"
Thing HM-DW-WM PEQ0549025 "Teppenlich Dimmer" @ "Flur EG/OG"
Thing HM-LC-Sw1-Pl-CT-R1 QEQ0556419 "Garagentor" @ "Garagentor"
Thing HmIP-SWDM 00155BE9A441C3 "Sensor Garagentor" @ "Sensor Garagentor"
Thing HmIP-SWDM 00155BE9A443D2 "Sensor Garagentuer" @ "Sensor Garagentuer"
Thing HmIP-FSM16 000B9D898A4B12 "Magnetventil Pumpe" @ "MagnetVentilPumpe"
Thing HMIP-PS 00021D89AD48E7 "Soundsystem" @ "Soundsystem"
Thing HmIP-PSM-2 0034DF2991D5F7 "Rescue Box" @ "RescueBox"
Thing HmIP-PSM-2 0034DF2991CBDB "Waermepumpe" @ "Waermepumpe"
Thing HmIP-SWD 001898A99273BC "HAR Wassermelder" @ "HAR Wassermelder"
