Homematic java.util.concurrent.TimeoutException
Hey guys,
since few days i receive some error logs related to my homematic. several items are not available and after few minutes everything seems to be fine.
Can you help me to identify the reason?
CCU3 (debmatic) and openHAB 3.3.0.M3
Binding Homematic 3.3.0.M3
are on the same PI
java -version
openjdk version “11.0.14” 2022-01-18
OpenJDK Runtime Environment (build 11.0.14+9-post-Raspbian-1deb11u1)
OpenJDK Server VM (build 11.0.14+9-post-Raspbian-1deb11u1, mixed mode)
```yaml
2022-04-07 12:33:19.801 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.TimeoutException
2022-04-07 12:33:49.822 [WARN ] [ternal.handler.HomematicThingHandler] - java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2022-04-07 12:34:40.593 [WARN ] [ternal.handler.HomematicThingHandler] - Could not reinitialize the device '00111BE99286E5': java.util.concurrent.TimeoutException
java.io.IOException: java.util.concurrent.TimeoutException
	at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:121) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:73) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setChannelDatapointValues(RpcClient.java:244) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.setChannelDatapointValues(AbstractHomematicGateway.java:522) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.CcuGateway.setChannelDatapointValues(CcuGateway.java:109) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadChannelValues(AbstractHomematicGateway.java:492) ~[?:?]
	at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.loadHomematicChannelValues(HomematicThingHandler.java:485) ~[?:?]
	at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.updateStatus(HomematicThingHandler.java:503) ~[?:?]
	at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.deviceLoaded(HomematicThingHandler.java:669) ~[?:?]
	at org.openhab.binding.homematic.internal.handler.HomematicBridgeHandler.onDeviceLoaded(HomematicBridgeHandler.java:339) ~[?:?]
	at org.openhab.binding.homematic.internal.handler.HomematicBridgeHandler.onNewDevice(HomematicBridgeHandler.java:301) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.newDevices(AbstractHomematicGateway.java:771) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleNewDevice(RpcResponseHandler.java:108) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleMethodCall(RpcResponseHandler.java:57) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.server.XmlRpcServer$ResponseHandler.handle(XmlRpcServer.java:125) ~[?:?]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: java.util.concurrent.TimeoutException
	at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:109) ~[?:?]
	at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:111) ~[?:?]
	... 31 more
2022-04-07 12:34:40.673 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarAlarmZone1}' contains invalid characters, new Datapoint name '__sysVarAlarmZone1_'
2022-04-07 12:34:40.674 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarPresence}' contains invalid characters, new Datapoint name '__sysVarPresence_'
2022-04-07 12:34:40.688 [WARN ] [ternal.handler.HomematicThingHandler] - Datapoint 'GWE00000000:2#__ruleTmpProgramName_' not found on gateway '3014F711A0001F58A9A71BCE'
2022-04-07 12:35:25.691 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-BROLL:3014F711A0001F58A9A71BCE:00111BE99286E5' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException
Hi Simon,
does this alway happen for the same device or device type? Or for different devices?
What kind of Raspi is it?
Hi this happens for some random devices.
Its an Raspberry 4 with 4gb RAM and Debianos.
This kind of problems is really hard to debug. I don’t know anything about debmatic. But I think that there are also log files in debmatic (maybe you have to increase a log level). Can you check these logs whether there are any entries at the same time(s) the problem in OH happens?
Some Logs from the CCU3
Mai 1 00:02:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:07:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:12:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:17:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:22:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:27:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:31:54 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-2] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.1.119:9125
Mai 1 00:31:54 de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendNotificationHandler INFO  [f0364351-a82b-4e06-be95-5a8f8328d27e_WorkerPool-0] SYSTEM: LegacyBackendNotificationHandler Verticle or Worker started
Mai 1 00:31:54 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO  [vert.x-worker-thread-4] init finished
Mai 1 00:31:54 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer INFO  [vert.x-worker-thread-4] Added InterfaceId: f0364351-a82b-4e06-be95-5a8f8328d27e
Mai 1 00:31:54 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO  [vert.x-eventloop-thread-5] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://192.168.1.119:9125
Mai 1 00:31:54 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO  [vert.x-eventloop-thread-5] Added InterfaceId: f0364351-a82b-4e06-be95-5a8f8328d27e
Mai 1 00:31:54 de.eq3.ccu.virtualdevice.service.internal.rega.BackendWorker INFO  [vert.x-worker-thread-16] Execute BackendCommand: de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand
Mai 1 00:31:54 de.eq3.cbcs.legacy.bidcos.rpc.internal.DeviceUtil INFO  [vert.x-worker-thread-4] updateDevicesForClient f0364351-a82b-4e06-be95-5a8f8328d27e -> 205 device addresses will be added
Mai 1 00:32:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:37:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:41:54 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer ERROR [vert.x-worker-thread-4] IO Exception: Could not add interface: f0364351-a82b-4e06-be95-5a8f8328d27e
de.eq3.cbcs.legacy.communication.rpc.RpcIOException: java.net.SocketTimeoutException: Read timed out
	at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:110)
	at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.sendRequest(RpcClient.java:94)
	at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.invoke(RpcClient.java:82)
	at com.sun.proxy.$Proxy23.newDevices(Unknown Source)
	at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendClient.newDevices(LegacyBackendClient.java:157)
	at de.eq3.cbcs.legacy.bidcos.rpc.internal.DeviceUtil.synchronizedBackendDevices(DeviceUtil.java:230)
	at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:109)
	at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:26)
	at io.vertx.core.eventbus.impl.HandlerRegistration.deliver(HandlerRegistration.java:212)
	at io.vertx.core.eventbus.impl.HandlerRegistration.handle(HandlerRegistration.java:191)
	at io.vertx.core.eventbus.impl.EventBusImpl.lambda$deliverToHandler$3(EventBusImpl.java:505)
	at io.vertx.core.impl.ContextImpl.lambda$wrapTask$2(ContextImpl.java:337)
	at io.vertx.core.impl.TaskQueue.lambda$new$0(TaskQueue.java:60)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.net.SocketTimeoutException: Read timed out
	at java.base/java.net.SocketInputStream.socketRead0(Native Method)
	at java.base/java.net.SocketInputStream.socketRead(SocketInputStream.java:115)
	at java.base/java.net.SocketInputStream.read(SocketInputStream.java:168)
	at java.base/java.net.SocketInputStream.read(SocketInputStream.java:140)
	at org.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:160)
	at org.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:84)
	at org.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:273)
	at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:140)
	at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:57)
	at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:261)
	at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:283)
	at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:259)
	at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:232)
	at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:272)
	at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:124)
	at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:686)
	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:488)
	at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55)
	at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:106)
	... 15 more
Mai 1 00:42:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:47:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:52:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 00:57:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 01:02:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 01:07:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 01:12:00 de.eq3.cbcs.server.core.otau.DeviceBackgroundUpdateSubsystem INFO  [vert.x-eventloop-thread-2] SYSTEM: Permanent-/Burstlistener Handler utilization: 0/50 used
Mai 1 01:15:05 org.apache.http.impl.client.DefaultHttpClient INFO  [HmIP-RF_java_WorkerPool-1] I/O exception (java.net.SocketException) caught when processing request to {}->http://127.0.0.1:39292: Datenübergabe unterbrochen (broken pipe) (Write failed)
Mai 1 01:15:05 org.apache.http.impl.client.DefaultHttpClient INFO  [HmIP-RF_java_WorkerPool-1] Retrying request to {}->http://127.0.0.1:39292
and the Logs from openhab:
2022-05-01 00:31:09.584 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection lost on gateway '3014F711A0001F58A9A71BCE', cause: "IOException java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@11305d6::SocketChannelEndPoint@12aab27{l=/192.168.1.119:50214,r=/192.168.1.119:2001,ISHUT,fill=-,flush=-,to=12/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@11305d6(l:/192.168.1.119:50214 <-> r:/192.168.1.119:2001,closed=false)=>HttpChannelOverHTTP@12a6167(exchange=HttpExchange@86b632{req=HttpRequest[POST / HTTP/1.1]@1683fc1[TERMINATED/null] res=HttpResponse[null 0 null]@15fc498[PENDING/null]})[send=HttpSenderOverHTTP@1e6afcd(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@e8bea5{s=START}],recv=HttpReceiverOverHTTP@e0180e(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]"
2022-05-01 00:31:54.669 [INFO ] [ommunicator.AbstractHomematicGateway] - Connection resumed on gateway '3014F711A0001F58A9A71BCE'
2022-05-01 00:32:04.759 [WARN ] [ernal.handler.HomematicBridgeHandler] - Device with address '0026DD89943172' not found on gateway '3014F711A0001F58A9A71BCE'
2022-05-01 00:34:25.098 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
2022-05-01 00:38:28.887 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@494b55' takes more than 5000ms.
2022-05-01 00:39:08.727 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarAlarmZone1}' contains invalid characters, new Datapoint name '__sysVarAlarmZone1_'
2022-05-01 00:39:08.728 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarPresence}' contains invalid characters, new Datapoint name '__sysVarPresence_'
2022-05-01 00:39:08.738 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${ruleTmpProgramName}' contains invalid characters, new Datapoint name '__ruleTmpProgramName_'
2022-05-01 00:39:55.169 [WARN ] [ternal.handler.HomematicThingHandler] - Could not reinitialize the device '00111BE99286E5': java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
java.io.IOException: java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
Caused by: java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
        at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
        at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:110) ~[?:?]
        ... 31 more
Caused by: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
        at org.eclipse.jetty.client.HttpConnection$RequestTimeouts.onExpired(HttpConnection.java:334) ~[?:?]
        at org.eclipse.jetty.client.HttpConnection$RequestTimeouts.onExpired(HttpConnection.java:314) ~[?:?]
        at org.eclipse.jetty.io.CyclicTimeouts.onTimeoutExpired(CyclicTimeouts.java:110) ~[?:?]
        at org.eclipse.jetty.io.CyclicTimeouts.access$100(CyclicTimeouts.java:50) ~[?:?]
        at org.eclipse.jetty.io.CyclicTimeouts$Timeouts.onTimeoutExpired(CyclicTimeouts.java:196) ~[?:?]
        at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:298) ~[?:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
        ... 1 more
2022-05-01 00:41:55.861 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
2022-05-01 00:42:19.116 [ERROR] [ommunicator.AbstractHomematicGateway] - java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@60e87c::SocketChannelEndPoint@677f90{l=/192.168.1.119:56050,r=/192.168.1.119:9292,ISHUT,fill=-,flush=-,to=11533/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@60e87c(l:/192.168.1.119:56050 <-> r:/192.168.1.119:9292,closed=false)=>HttpChannelOverHTTP@d92344(exchange=HttpExchange@ea11b0{req=HttpRequest[POST /groups HTTP/1.1]@1943959[TERMINATED/null] res=HttpResponse[null 0 null]@285504[PENDING/null]})[send=HttpSenderOverHTTP@1ee9986(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1c563da{s=START}],recv=HttpReceiverOverHTTP@17bc98a(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@60e87c::SocketChannelEndPoint@677f90{l=/192.168.1.119:56050,r=/192.168.1.119:9292,ISHUT,fill=-,flush=-,to=11533/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@60e87c(l:/192.168.1.119:56050 <-> r:/192.168.1.119:9292,closed=false)=>HttpChannelOverHTTP@d92344(exchange=HttpExchange@ea11b0{req=HttpRequest[POST /groups HTTP/1.1]@1943959[TERMINATED/null] res=HttpResponse[null 0 null]@285504[PENDING/null]})[send=HttpSenderOverHTTP@1ee9986(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1c563da{s=START}],recv=HttpReceiverOverHTTP@17bc98a(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
        at org.openhab.binding.homematic.internal.communicator.client.RpcClient.listDevices(RpcClient.java:211) ~[?:?]
        at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getDeviceDescriptions(AbstractHomematicGateway.java:453) ~[?:?]
        at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.newDevices(AbstractHomematicGateway.java:763) ~[?:?]
Caused by: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@60e87c::SocketChannelEndPoint@677f90{l=/192.168.1.119:56050,r=/192.168.1.119:9292,ISHUT,fill=-,flush=-,to=11533/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@60e87c(l:/192.168.1.119:56050 <-> r:/192.168.1.119:9292,closed=false)=>HttpChannelOverHTTP@d92344(exchange=HttpExchange@ea11b0{req=HttpRequest[POST /groups HTTP/1.1]@1943959[TERMINATED/null] res=HttpResponse[null 0 null]@285504[PENDING/null]})[send=HttpSenderOverHTTP@1ee9986(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1c563da{s=START}],recv=HttpReceiverOverHTTP@17bc98a(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
        ... 24 more
Caused by: java.io.EOFException: HttpConnectionOverHTTP@60e87c::SocketChannelEndPoint@677f90{l=/192.168.1.119:56050,r=/192.168.1.119:9292,ISHUT,fill=-,flush=-,to=11533/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@60e87c(l:/192.168.1.119:56050 <-> r:/192.168.1.119:9292,closed=false)=>HttpChannelOverHTTP@d92344(exchange=HttpExchange@ea11b0{req=HttpRequest[POST /groups HTTP/1.1]@1943959[TERMINATED/null] res=HttpResponse[null 0 null]@285504[PENDING/null]})[send=HttpSenderOverHTTP@1ee9986(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@1c563da{s=START}],recv=HttpReceiverOverHTTP@17bc98a(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:376) ~[?:?]
        at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1614) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:259) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:181) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[?:?]
        at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
        at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
        ... 11 more
Please excuse my late answer. I am quite busy currently.
The problem seems to happen deep in the communication between OH and the CCU. It is nearly impossible to debug. A possible solution could be to intercept this exception and retry again.
Hi martin, if you could explain to me what i should do, i could try to intercept it.
This has to be implemented within the binding. There is already some sort of retry mechanism for the communication between OH and the CCU but it seems that it is not sufficient.
I have installed new openhabian Image and the issue seems to be gone.:grin:
