i am relatively new to OpenHab but i am very impressed how powerful this technology is and will become.
I am running Openhabian on a Raspberry Pi 2 and installed KNX,Homematic and 1-Wire Binding. I got everything working with Rules Sitemaps and so on. The only issue i have that i can’t figure out is:
my Homematic CCU2 always needs to be booted completely before i can use it in OpenHab. This makes me rebooting the Pi pretty often. Is there a possibility to "re"initialize the Homematic Binding automatically while OpenHab is running ?
I am working on a mobile Exibition case which was formerly used for KNX demonstration purposes. I am converting the case to show how integrating multiple Smart Home Systems can work. For that reason i have one plug activating all the Systems(including Openhab) at the same time. KNX for example is working right away. To make Homematic work i have to reboot OpenHab after CCU is completely booted.
This is what the OpenHab log shows me when i started all the Systems.
2017-11-23 14:25:38.646 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 323 seconds from gateway ‘CCU2’, restarting RPC server
2017-11-23 14:25:38.778 [WARN ] [matic.handler.HomematicBridgeHandler] - Device with address ‘JEQ0077618’ not found on gateway 'CCU2’
2017-11-23 14:25:38.781 [WARN ] [matic.handler.HomematicBridgeHandler] - Device with address ‘GWE00000000’ not found on gateway 'CCU2’
2017-11-23 14:25:38.785 [WARN ] [matic.handler.HomematicBridgeHandler] - Device with address ‘NEQ0357210’ not found on gateway ‘CCU2’
The Bridge is online, but all the other Devices can’t be found. Only a reboot of OpenHab seems to solve the Problem.
Ah I see.
This sounds a lot like a problem I had a while back and did never really further investigate (I should do that!). You should read up on it and try what was suggested there:
