with a clean install of openhabian 1.4 and update to openHAB 2.2.0 stable I installed the Homematic Binding. First the Homematic Bridge ccu2 was online and I was able to add the MH-Things. After a few minutes the ccu2 gets offline.
Clearing the cache made it worse and after reboot I get the error message:
2017-12-19 17:46:37.844 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_1,2,22426569) has been shut down
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
Before I had it working under openhabian 1.3. Any idea?
- Platform information:
- Hardware: Raspi 3
- OS: openhabian 1.4
- Java Runtime Environment: which java platform is used and what version?
- openHAB version: 2.20 stable
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
