while modifying some of my rules I figured out the OTA for my switches are not (no more) working.
Is there a known bug with OH3(.1 M4) in the homematic binding?
I can set the OTA number item to a value but the related switch doesn’t switch off after this time has expired. Just stays on forever.
The OTA feature was working as expected within the same rules on OH2.5
My environment:
OH3.1 milestone 4 in a docker container on raspberry 4 5.10.17-v7l+
using RaspberryMatic V3.57.5.20210424 as bridge
to connect to a HmIP-MOD-OC8
you triggered an idea with me.
I haven’t had an On_Time item for this channel. But an On_Time_Automatic item which I am using to set the time value.
So my first step was to create an On_Time item. Which immediately after creation changed from NULL to the value I had applied to OTA and the OTA functionality starts working as expected!
So my lesson learned, please correct or confirm:
On_Time_Automatic isn’t a functionality provided by HM or HM-IP but by the OpenHab binding
In order to have it working you will need to have the On_Time item for the same channel defined. Even if you aren’t using it in your rules/sitemaps.
The device has got data points named “ON_TIME”, i.e. the binding creates a channel with the same name and this one will be used to communicate directly with the device.
I have searched the Java code and your assumption is correct. on_time_automatic is created by the binding :-).
