Hi there,
There is no chance for me getting it started, respectively run it for a time. Everytime I installed the binding and added the homematic things everything works. But for a time of from 5 till 10 minutes, ony by one thing changes from online to offline. At this time i also lost my WebUI connection to the homematic CCU.
My setup:
Raspberrry Pi 3 runnning openhabian
Homematic CCU2 with different Homematic IP products (they all went fine at the CCU)
I tried a lot of things without success. Also changed my CCU cause i thougt that could be the problem.
Here’s my openhab.log
2017-11-02 21:50:57.562 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘64f49799’ not available, disabling support
2017-11-02 21:50:57.635 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘64f49799’ not available, disabling support
2017-11-02 21:50:57.864 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.29.23,address=OEQ0458232,wired=false,hmip=true,cuxd=false,group=true]
2017-11-02 21:51:08.886 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HM-RCV-50:64f49799:BidCoS-RF’ to inbox.
2017-11-02 21:51:08.916 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘${sysVarAlarmZone1}’ contains invalid characters, new Datapoint name '_sysVarAlarmZone1’
2017-11-02 21:51:08.918 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name ‘${sysVarPresence}’ contains invalid characters, new Datapoint name '_sysVarPresence’
2017-11-02 21:51:08.985 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:GATEWAY-EXTRAS-64F49799:64f49799:GWE00000000’ to inbox.
2017-11-02 21:53:12.171 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HMIP-SWDO:64f49799:0000D7099A740D’ to inbox.
2017-11-02 21:55:54.747 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-STH:64f49799:000E57098F2295’ to inbox.
2017-11-02 21:57:45.489 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-BSM:64f49799:000855699C341D’ to inbox.
2017-11-02 22:26:09.007 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 335 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:27:19.502 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 406 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:27:34.677 [WARN ] [ommunicator.AbstractHomematicGateway] - null
java.io.IOException
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:113)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:82)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.release(RpcClient.java:91)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.stopServers(AbstractHomematicGateway.java:241)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.access$3(AbstractHomematicGateway.java:238)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$EventTrackerThread.run(AbstractHomematicGateway.java:823)[186:org.openhab.binding.homematic:2.1.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:109)[68:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:655)[68:org.eclipse.jetty.client:9.2.19.v20160908]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:99)[186:org.openhab.binding.homematic:2.1.0]
… 12 more
2017-11-02 22:30:22.595 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 589 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:30:37.687 [WARN ] [ommunicator.AbstractHomematicGateway] - null
java.io.IOException
… 12 more
2017-11-02 22:31:37.714 [ERROR] [ommunicator.AbstractHomematicGateway] - null
java.io.IOException
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:117)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.addChannelDatapoints(RpcClient.java:150)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.addChannelDatapoints(CcuGateway.java:168)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.newDevices(AbstractHomematicGateway.java:685)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleNewDevice(RpcResponseHandler.java:101)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleMethodCall(RpcResponseHandler.java:52)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.server.XmlRpcServer$ResponseHandler.handle(XmlRpcServer.java:141)[186:org.openhab.binding.homematic:2.1.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
… 16 more
2017-11-02 22:31:42.580 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘homematic:HmIP-PCBS:64f49799:0004570993E81A’ to inbox.
2017-11-02 22:32:56.838 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 743 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:33:14.132 [ERROR] [ommunicator.AbstractHomematicGateway] - java.net.ConnectException: Connection refused
java.io.IOException: java.net.ConnectException: Connection refused
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.listDevices(RpcClient.java:140)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getDeviceDescriptions(AbstractHomematicGateway.java:447)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.newDevices(AbstractHomematicGateway.java:681)[186:org.openhab.binding.homematic:2.1.0]
Caused by: java.util.concurrent.ExecutionException: java.net.ConnectException: Connection refused
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118)[68:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:110)[68:org.eclipse.jetty.client:9.2.19.v20160908]
… 16 more
Caused by: java.net.ConnectException: Connection refused
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)[:1.8.0_121]
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:717)[:1.8.0_121]
at org.eclipse.jetty.io.SelectorManager.finishConnect(SelectorManager.java:341)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.io.SelectorManager$ManagedSelector.processConnect(SelectorManager.java:676)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.io.SelectorManager$ManagedSelector.processKey(SelectorManager.java:645)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.io.SelectorManager$ManagedSelector.select(SelectorManager.java:612)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.io.SelectorManager$ManagedSelector.run(SelectorManager.java:550)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.NonBlockingThread.run(NonBlockingThread.java:52)[83:org.eclipse.jetty.util:9.2.19.v20160908]
… 3 more
2017-11-02 22:33:17.135 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection lost on gateway '64f49799’
2017-11-02 22:33:17.137 [ERROR] [ommunicator.AbstractHomematicGateway] - Connection refused (Connection refused)
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_121]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_121]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_121]
at org.openhab.binding.homematic.internal.communicator.client.SocketHandler.getSocket(SocketHandler.java:45)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:87)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:102)[186:org.openhab.binding.homematic:2.1.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:78)[186:org.openhab.binding.homematic:2.1.0]
2017-11-02 22:33:17.165 [ERROR] [ommunicator.AbstractHomematicGateway] - RPC client for interface RF not available
java.io.IOException: RPC client for interface RF not available
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getRpcClient(AbstractHomematicGateway.java:300)[186:org.openhab.binding.homematic:2.1.0]
2017-11-02 22:33:17.170 [ERROR] [ommunicator.AbstractHomematicGateway] - RPC client for interface RF not available
2017-11-02 22:33:17.146 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection refused (Connection refused)
2017-11-02 22:33:17.204 [WARN ] [ommunicator.AbstractHomematicGateway] - RPC client for interface HMIP not available
java.io.IOException: RPC client for interface HMIP not available
2017-11-02 22:33:17.213 [WARN ] [ommunicator.AbstractHomematicGateway] - RPC client for interface GROUP not available
java.io.IOException: RPC client for interface GROUP not available
2017-11-02 22:33:17.241 [WARN ] [ommunicator.AbstractHomematicGateway] - RPC client for interface RF not available
2017-11-02 22:33:48.478 [INFO ] [ommunicator.AbstractHomematicGateway] - Connection resumed on gateway '64f49799’
2017-11-02 22:38:17.245 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 300 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:38:50.706 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.internal.ThingManager@141aaf4’ takes more than 5000ms.
2017-11-02 22:39:27.782 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 370 seconds from gateway ‘64f49799’, restarting RPC server
2017-11-02 22:40:24.526 [WARN ] [ome.core.thing.internal.ThingManager] - Disposing handler for thing ‘homematic:bridge:64f49799’ takes more than 5000ms.
2017-11-02 22:40:28.266 [ERROR] [ematic.handler.HomematicThingHandler] - null
Hoping someone can solve my problem
