rule "open garage gate by Status_Entrance"
Item Status_Entrance_Top received command or
Item Status_Entrance_Top_s received command or
Item Status_Entrance_Top_l received command
logInfo("Status_Entrance", "triggering garage gate")
//Switch_Garage_Gate.sendCommand(ON)
if (Gate_Garage.state == OPEN)
Status_Entrance_Line1.sendCommand("schlieĂt")
else
Status_Entrance_Line1.sendCommand("öffnet")
Status_Entrance_Submit.sendCommand(ON)
Sending and receiving text lines work (but there is no reaction to my rule, neither logging nor text lines), so in general the setup is ok. Any suggestions?
When pressing long, I get the error âUnknown value âCONTâ for PRESS virtual datapoint, only SHORT,LONG,LONG_RELEASE allowedâ, is this related?
There was a problem with âCONTâ which was fixed in January 2018. This was after the release of 2.2. You could try with the latest snapshot release.
Ok, I will give it a try, thank you. This is probably not to be discussed in this thread, but are the addon releases bound to the main OH version number? There should be maintenance releases of addons inbetween two OH releases. At least, I was hoping to get bugfixes easier and continuously by switching to the package distribution of OH. I donât mean to be rude (my comment is rather general than specific to the homematic addon), but manually installing snapshot versions was pretty much what I was hoping to avoid. I will try it nonetheless.
maybe this was not such a good idea after all. Now updated all to 2.3.0.20180314⊠and nothing is working anymore. Karaf is not starting many bundles, among them core, ui, the bindings, transformations etc⊠I know what Iâll do for the rest of the eveningâŠ
Hmmm, I have tried 2.3 Build 1221 and no problems with a clean installation (on Windows). But I did not test it with production environment on the raspi.
So good luck âŠ
Some feedback from my testingâŠ
Button presses work when reacting on âchanged to ONâ events, not âreceived commandâ.
Text transmission only works for lines 2 and 3. The button descriptions cannot be changed, and also the 3rd line in the middle (presumably line 4) cannot be set. The EP-Thing has only 3 lines, not 5.
Did someone manage to change the button text or the 3 middle line?
It is definitly not possible to change the button texts via the binding, but the three lines in the middle can be set (at least with binding version 2.1). I am not at home, so I canât post my rule code, but I can check it this weekend and post the rule code here.
I created a slightly modified version of my rule that is running on OH 2.1:
rule "Info-Anzeige"
Item Fenster_Arbeitszimmer changed or
Item Fenster_Bad changed or
Item Fenster_Schlafzimmer changed or
Item Tuer_Wohnzimmer changed or
Item Balkon_Temperatur changed
val temp = "Line 1"
sendCommand(DT_L1, temp)
sendCommand(DT_Icon1, "OK")
var fensterIcon = "OK";
sendCommand(DT_Icon2, fensterIcon)
sendCommand(DT_L2, "Line 2")
sendCommand(DT_L3, "Line 3")
sendCommand(DT_Icon3, "ON")
sendCommand(DT_Submit, ON) // always execute at the end
Item DT_L1 ist connected with channel DISPLAY_LINE_1, DT_L2 with channel DISPLAY_LINE_2, âŠ
Thanks a lot for the good feedback! Well, my lines are off by 1, so when I write to line 2, it appears where you have line 1. Text written to line 1 does not appear anywhereâŠ
I assume it is related to this update, where @Thomas_G mentioned that the lines have been shifted? I think it made things worse for the EP device. Could you make that last change only for the OLED version and revert for EP?
@gerrieg Yes, they are really âinterestingâ devices :-).
Strictly speaking, the EP device has got 5 lines. But via the binding only the 3 lines in the middle can be set (see my picture above). In version 2.1 of the binding there were 3 channels for the text and 3 channels for the icons:
DISPLAY_LINE_1 to DISPLAY_LINE_3 and DISPLAY_ICON_1 to DISPLAY_ICON_3.
In the next days I can find some time for testing (and probably migrating my production environment to 2.3).
The OLED HM-DIS-WM55 device has 6 lines. Your changes made the device completely usable. (One more line and shifting the content one line up).
For the EP device you must revert the shifting-change. But only for EP, not for âmyâ device.
I think that is the only âTo-Doâ.
Thatâs what I interpret here.
Hi @gerrieg, did you have time to fix this issue? Would help me a lot because right now, I cannot use the device properly. When you make the changes in a snapshot I can test it right away.
