Hello everyone!
I’m using the latest openHAB 2.2 snapshot and Homegear version 0.7.8-1314.
Every Homematic device/thing exposes an Item called UNREACH, reflecting the unreachable information also visible in homegear directly. I’m seeing the issue, that these are not correctly loaded. A typical scenario is a reboot of my RPi. After I gave openHAB a few minutes to initialize, it got the unreachable state for some devices, not all. This will not change over the coming minutes, hours or days.
All Homematic things are ONLINE, the other items of the devices are working correctly.
The problem seems to be, that the binding does not reliably request or receive this channel. Is that behavior known or reproducible on other systems?
openhab> smarthome:items list | grep gUnreach
BD_Deckenlicht_Unreach (Type=SwitchItem, State=NULL, Label=Bad Deckenlicht unreachable, Category=siren, Groups=[gW, gUnreach])
BD_Fenster_Unreach (Type=SwitchItem, State=OFF, Label=Bad Fenster unreachable, Category=siren, Groups=[gW, gUnreach])
BD_Heizung_Unreach (Type=SwitchItem, State=NULL, Label=BD_Heizung unreachable, Category=siren, Groups=[gBDHeat, gUnreach])
BD_Tuer_Unreach (Type=SwitchItem, State=OFF, Label=Bad Tür unreachable, Category=siren, Groups=[gW, gUnreach])
BD_Waschmaschine_Unreach (Type=SwitchItem, State=NULL, Label=Waschmaschine unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Edison_Dimmer_Unreach (Type=SwitchItem, State=NULL, Label=Edison Dimmer unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Fenster_Unreach (Type=SwitchItem, State=OFF, Label=Küche Fenster unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Heizung_Unreach (Type=SwitchItem, State=NULL, Label=FK_Heizung unreachable, Category=siren, Groups=[gFKHeat, gUnreach])
FK_Kuehlschrank_Unreach (Type=SwitchItem, State=NULL, Label=Kühlschrank unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Spuelmaschine_Unreach (Type=SwitchItem, State=NULL, Label=Spülmaschine unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Taster_Schrank_Unreach (Type=SwitchItem, State=OFF, Label=Küchenschrank Taster unreachable, Category=siren, Groups=[gW, gUnreach])
FK_Taster_Tokyo_Unreach (Type=SwitchItem, State=NULL, Label=Flur Taster Tokyo unreachable, Category=siren, Groups=[gW, gUnreach])
