I added automatically my weatherstation via homemactic binding but it shows only humidity and not temp, airspeed and so on.
Can someone help me?
can you please give some more information about your environment?
i use : openHAB 3.0.2 on an Raspberry Pi , Homematic CCU3 and the Device is an Homematic weather sensor basic
Hi Markus,
a possible reason for this problem could be that the channels resp. items do not have correct types.
Did you definie the items in Main UI or in files?
Can you please perform the following steps
Maybe there are also some error messages with additional information.
