Hey there,
I´m getting crazy…
I read many Topics and Websites und tried out many variants of coding, but it won´t work.
In my basicUI I can see an entry for my window:
Text item=dEG_Wohnzimmer
I have configured it in many ways:
//Number dEG_Wohnzimmer “Balkontür [MAP(kontakte.map):%d]” (dEG_Wohnzimmer) {homematic=“address=xxxxxxxxxx, channel=1, parameter=STATE, forceUpdate=true” }
//Contact dEG_Wohnzimmer “Balkontür Wohnzimmer [%s]” (dEG_Wohnzimmer){homematic=“address=xxxxxxxxxx, channel=1, parameter=STATE, forceUpdate=true” }
//String dEG_Wohnzimmer “Balkontür” { channel=“homematic:HM-Sec-SCo:yyyyyyyy:xxxxxxxxxx:1#STATE” }
//Number dEG_Wohnzimmer “Balkontür [MAP(kontakte.map):%d]” (dEG_Wohnzimmer) { homematic=“xxxxxxxxxx:1#STATE” }
Number dEG_Wohnzimmer “Balkontür Wohnzimmer ist [MAP(kontakte.map):%s]” {homematic=“address=xxxxxxxxxx, channel=1, parameter=STATE”}
None of it really works. The last gives me the return “UNKNOWN” after all.
In my PaperUI the state changes when I open and Close the door. But not in the Basic UI
here my kontakte.map:
0=zu
1=offen
-=UNKNOWN
CLOSED=zu
OPEN=offen
TILTED=tilted
undefined=unknown
offen=offen
geschlossen=zu
OFFEN=offen
GESCHLOSSEN=zu
2016-11-19 17:25:35.850 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2016-11-19 17:25:35.852 [WARN ] [.core.transform.TransformationHelper] - couldn’t transform value because transformationService of type ‘MAP’ is unavailable
2016-11-19 17:36:25.418 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ‘NULL’ with the file ‘kontakte.map’ : Target value not found in map for 'NULL’
It sounds to me that the value is empty???
I presume, you are using homegear and the contacts are paired in there and you can see Data is changing when contact changes.
You are using Homematic Binding binding-homematic - 2.0.0.b4.
In the Paper UI --> configurations --> things you see the bridge and the contact.
I use the Window contact, not the ones mounted at the handle. SO the item definition might be different.
For the window contact it is:
Contact ReserveFensterSchalter “Reserve Fensterkontakt [MAP(windowcontact.map):%d]” (Fensterkontakte, TestKram) { channel=“homematic:HG-BC-SC-Rd-WM-2:d9b779d0:MEQ1800159:1#STATE”}
Contact BatReserveFensterSchalter “Batterie Reserve Fensterkontakt [MAP(battery.map):%s]” (BatFensterkontakte) { channel=“homematic:HG-BC-SC-Rd-WM-2:d9b779d0:MEQ1800159:0#LOWBAT”}
Number SignalReserveFensterSchalter “Signalstärke ReserveFensterschalter [%d]” (SigFensterkontakte) { channel=“homematic:HG-BC-SC-Rd-WM-2:d9b779d0:MEQ1800159:0#RSSI_DEVICE”}
For the 2.0 binding it has to be channel not homematic. The rest (homematic:HG-BC-SC-Rd-WM-2:d9b779d0:MEQ1800159:0#RSSI_DEVICE) can be copied from the “Thing” itself by clicking on it. The page with different channels appears.
the d9b779d0 refers to the ID of the bridge, so must correspond to the ID of your homegear bridge and is set automaticly by OH2. Just if you (as I did) kick out the binding and set it in again, this ID changes and has to be changed in your Item definition.
wich item (contact,…) you have to use can be seen somewhere in the Paper UI or habmin. Idon’t remember where i have seen it and I don’t find it anymore
I’m looking forward to have a doku…
hope that helps
