openHAB 2 runs on RaspBerry Pi 3B (openHABian) with HM-MOD-RPI-PCB and Homegear.
Everything works so far, only in the log is the following warning:
07:03:05.279 [WARN ] [ternal.communicator.HomematicGateway] - Address already in use (Bind failed)
Your Homematic binding works, you can control HM devices but the log entry is still there? Maybe you have set the HM bridge twice? One time in the paper UI and another time in some config file?
The error means that there is already a program running that is using a port that HonematicGateway wants to use. You will need to figure out how to make the binding use a different port (I don’t know this binding) or how to make the other program using this port to use and alternative port.
I have the logging for org.openhab.binding.homematic on DEBUG put and the following has come out:
13:30:21.320 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC server
13:30:21.321 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9126
13:30:21.322 [WARN ] [ternal.communicator.HomematicGateway] - Address already in use (Bind failed)
So the port 9126 is the problem.
The homematic:bridge uses the port 9126.
BIN-RPC Callback Port
Callback port of the openHAB BIN-RPC server. If no value is specified, xmlCallbackPort starts with 9126 and counts up
And java uses the port 9126.
tcp6 0 0 :::9126 :::* LISTEN 10670/java
Which port should I change and what value can I use then?
