Maybe try a reset of the switch and re include it to your network?
MANUAL RESET - To be used only in the event that the network primary controller is lost or otherwise inoperable.)
(1) Turn switch on by tapping the top of the paddle once. (2) Quickly tap top of the paddle 3 times. (3) Quickly tap bottom of paddle
3 times. (4) If light turns off, switch is reset. If not, repeat manual reset.
After you asked if I had more than 1 of these (I have 3), and found that the switch I had removed/re-added to my Z-Wave network while upgrading the firmware was receiving the scene updates. I removed the other two from the network, re-added them back and am now in business
THANK YOU @Python !!!
Out of curiosity, have you updated the zwave binding recently (I donât see any versions mentioned)? Itâs possible that the thingType was updated and you hadnât deleted your Thing yet to update it. Itâs a lot easier to delete/rediscover Things than to exclude/reinclude.
