I have a Homeseer HSM100 motion, light, and temperature zwave sensor.It shows up in habmin but has the grey “uninitialized” dot next to it as an “EZMotion Express Wireless 3 in 1 Sensor” (I think the hardware is identical just with Homeseer branding).
The device does not appear to be configurable and it does not seem to send any motion events to openhab. Sorry if I am missing something obvious, I am just getting started with openhab.
Here is what I see in habmin.
Status:
Information
And here is what I see in the log when I push the button on the device to put it into configuration mode:
`14:16:10.490 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 5: Application Command Request (ALIVE:MANUFACTURER)
14:16:10.491 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 5: Incoming command class WAKE_UP
14:16:10.491 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 5: Received Wake Up Request
14:16:10.491 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 5: Received WAKE_UP_NOTIFICATION
14:16:10.491 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 5: Is awake with 2 messages in the wake-up queue.
14:16:10.491 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveWakeUpEvent
14:16:10.491 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
14:16:10.491 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1036 ] - NODE 5: Wakeup during initialisation.
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 5: Node advancer - MANUFACTURER: queue length(1), free to send(false)
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 5: Node advancer: loop - MANUFACTURER try 1: stageAdvanced(false)
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 5: Node advancer - advancing to VERSION
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 5: Node advancer: loop - VERSION try 0: stageAdvanced(true)
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking CONFIGURATION, version is 0
14:16:10.492 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:487 ] - NODE 5: Node advancer: VERSION - VERSION default to 1
14:16:10.493 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking MULTI_INSTANCE, version is 0
14:16:10.494 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:482 ] - NODE 5: Node advancer: VERSION - queued MULTI_INSTANCE
14:16:10.494 [DEBUG] [i.p.c.ZWaveVersionCommandClass:169 ] - NODE 5: Creating new message for application command VERSION_COMMAND_CLASS_GET command class MULTI_INSTANCE
14:16:10.494 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 5: Creating empty message of class = SendData (0x13), type = Request (0x00)
14:16:10.494 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking BATTERY, version is 0
14:16:10.494 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:487 ] - NODE 5: Node advancer: VERSION - VERSION default to 1
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking NO_OPERATION, version is 0
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:487 ] - NODE 5: Node advancer: VERSION - VERSION default to 1
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking NODE_NAMING, version is 0
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking WAKE_UP, version is 0
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:482 ] - NODE 5: Node advancer: VERSION - queued WAKE_UP
14:16:10.495 [DEBUG] [i.p.c.ZWaveVersionCommandClass:169 ] - NODE 5: Creating new message for application command VERSION_COMMAND_CLASS_GET command class WAKE_UP
14:16:10.495 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 5: Creating empty message of class = SendData (0x13), type = Request (0x00)
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking MANUFACTURER_SPECIFIC, version is 0
14:16:10.495 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking SENSOR_MULTILEVEL, version is 0
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:482 ] - NODE 5: Node advancer: VERSION - queued SENSOR_MULTILEVEL
14:16:10.496 [DEBUG] [i.p.c.ZWaveVersionCommandClass:169 ] - NODE 5: Creating new message for application command VERSION_COMMAND_CLASS_GET command class SENSOR_MULTILEVEL
14:16:10.496 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 5: Creating empty message of class = SendData (0x13), type = Request (0x00)
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking BASIC, version is 0
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:487 ] - NODE 5: Node advancer: VERSION - VERSION default to 1
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking ASSOCIATION, version is 0
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:479 ] - NODE 5: Node advancer: VERSION - checking VERSION, version is 0
14:16:10.496 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:491 ] - NODE 5: Node advancer: VERSION - queued 3 frames
14:16:10.497 [DEBUG] [b.z.i.protocol.ZWaveController:938 ] - Callback ID = 24
14:16:10.497 [DEBUG] [b.z.i.protocol.ZWaveController:620 ] - Enqueueing message. Queue length = 1
14:16:10.497 [DEBUG] [WaveController$ZWaveSendThread:1211 ] - Took message from queue for sending. Queue length = 0
14:16:10.497 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 5: Node advancer - queued packet. Queue length is 3
14:16:10.497 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 0A 00 13 05 03 86 13 60 25 18 28
14:16:10.497 [DEBUG] [b.z.i.protocol.ZWaveController:938 ] - Callback ID = 25
14:16:10.497 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 86 13 60 25 18 28
14:16:10.497 [DEBUG] [ApplicationCommandMessageClass:85 ] - Transaction not completed: node address inconsistent.
14:16:10.503 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 04 01 13 01 E8
14:16:10.503 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.503 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.503 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
14:16:10.503 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 04 01 13 01 E8
14:16:10.503 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
14:16:10.503 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 5: Sent Data successfully placed on stack.
14:16:10.515 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 05 00 13 18 00 F1
14:16:10.515 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.515 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.515 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 07 00 13 18 00 00 00 F3
14:16:10.515 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 07 00 13 18 00 00 00 F3
14:16:10.516 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 18 00
14:16:10.516 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 5: SendData Request. CallBack ID = 24, Status = Transmission complete and ACK received(0)
14:16:10.516 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 03 86 13 60
14:16:10.516 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 18 00
14:16:10.516 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
14:16:10.522 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 0A 00 04 00 05 04 86 14 60 02 00
14:16:10.523 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.523 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.523 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 0A 00 04 00 05 04 86 14 60 02 00
14:16:10.523 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 0A 00 04 00 05 04 86 14 60 02 00
14:16:10.523 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 04 86 14 60 02
14:16:10.523 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 5: Application Command Request (ALIVE:VERSION)
14:16:10.523 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 5: Incoming command class VERSION
14:16:10.523 [DEBUG] [i.p.c.ZWaveVersionCommandClass:78 ] - NODE 5: Received Version Request
14:16:10.523 [DEBUG] [i.p.c.ZWaveVersionCommandClass:98 ] - NODE 5: Process Version Command Class Report
14:16:10.523 [DEBUG] [i.p.c.ZWaveVersionCommandClass:108 ] - NODE 5: Requested Command Class = MULTI_INSTANCE, Version = 2
14:16:10.524 [DEBUG] [i.p.c.ZWaveVersionCommandClass:135 ] - NODE 5: Version = 2, version set. Enabling extra functionality.
14:16:10.525 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 03 86 13 60
14:16:10.525 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 04 86 14 60 02
14:16:10.525 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
14:16:10.525 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
14:16:10.525 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
14:16:10.525 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
14:16:10.525 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 5: Node advancer - VERSION: Transaction complete (SendData:Request) success(true)
14:16:10.534 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 5: Node advancer - checking initialisation queue. Queue size 3.
14:16:10.534 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 5: Node advancer - message removed from queue. Queue size 2.
14:16:10.534 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 5: Node advancer - VERSION: queue length(2), free to send(true)
14:16:10.534 [DEBUG] [b.z.i.protocol.ZWaveController:938 ] - Callback ID = 26
14:16:10.535 [DEBUG] [b.z.i.protocol.ZWaveController:620 ] - Enqueueing message. Queue length = 2
14:16:10.535 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 5: Node advancer - queued packet. Queue length is 2
14:16:10.535 [DEBUG] [b.z.i.protocol.ZWaveController:938 ] - Callback ID = 27
14:16:10.535 [DEBUG] [b.z.i.protocol.ZWaveController:620 ] - Enqueueing message. Queue length = 3
14:16:10.535 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 5: Response processed after 38ms/58ms.
14:16:10.535 [DEBUG] [WaveController$ZWaveSendThread:1211 ] - Took message from queue for sending. Queue length = 2
14:16:10.535 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 05 02 72 04 25 19 A8
14:16:10.536 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 72 04 25 19 A8
14:16:10.541 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 04 01 13 01 E8
14:16:10.541 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.541 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.541 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
14:16:10.541 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 04 01 13 01 E8
14:16:10.542 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
14:16:10.542 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 5: Sent Data successfully placed on stack.
14:16:10.553 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 05 00 13 19 00 F0
14:16:10.553 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.553 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.554 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 07 00 13 19 00 00 00 F2
14:16:10.554 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 07 00 13 19 00 00 00 F2
14:16:10.554 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 19 00
14:16:10.554 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 5: SendData Request. CallBack ID = 25, Status = Transmission complete and ACK received(0)
14:16:10.554 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 02 72 04
14:16:10.554 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 19 00
14:16:10.554 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false
14:16:10.562 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 0E 00 04 00 05 08 72 05 00 1E 00 02 00 01 92
14:16:10.562 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.563 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.563 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 0E 00 04 00 05 08 72 05 00 1E 00 02 00 01 92
14:16:10.564 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 0E 00 04 00 05 08 72 05 00 1E 00 02 00 01 92
14:16:10.564 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 08 72 05 00 1E 00 02 00 01
14:16:10.564 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 5: Application Command Request (ALIVE:VERSION)
14:16:10.564 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 5: Incoming command class MANUFACTURER_SPECIFIC
14:16:10.564 [DEBUG] [nufacturerSpecificCommandClass:66 ] - NODE 5: Received Manufacture Specific Information
14:16:10.565 [DEBUG] [nufacturerSpecificCommandClass:83 ] - NODE 5: Manufacturer ID = 0x001e
14:16:10.579 [DEBUG] [nufacturerSpecificCommandClass:84 ] - NODE 5: Device Type = 0x0002
14:16:10.579 [DEBUG] [nufacturerSpecificCommandClass:85 ] - NODE 5: Device ID = 0x0001
14:16:10.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 02 72 04
14:16:10.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 08 72 05 00 1E 00 02 00 01
14:16:10.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
14:16:10.579 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
14:16:10.579 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
14:16:10.580 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
14:16:10.580 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 5: Node advancer - VERSION: Transaction complete (SendData:Request) success(true)
14:16:10.580 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 5: Node advancer - checking initialisation queue. Queue size 2.
14:16:10.580 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 5: Response processed after 44ms/58ms.
14:16:10.580 [DEBUG] [WaveController$ZWaveSendThread:1211 ] - Took message from queue for sending. Queue length = 1
14:16:10.580 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 09 00 13 05 02 84 08 25 1B 50
14:16:10.580 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 84 08 25 1B 50
14:16:10.586 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 04 01 13 01 E8
14:16:10.586 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.587 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.587 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 04 01 13 01 E8
14:16:10.587 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 04 01 13 01 E8
14:16:10.587 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Response (0x01), payload = 01
14:16:10.587 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 5: Sent Data successfully placed on stack.
14:16:10.598 [DEBUG] [eController$ZWaveReceiveThread:1481 ] - Receive Message = 01 05 00 13 1B 00 F2
14:16:10.599 [DEBUG] [eController$ZWaveReceiveThread:1405 ] - Receive queue ADD: Length=1
14:16:10.599 [DEBUG] [b.z.i.protocol.ZWaveController:1163 ] - Receive queue TAKE: Length=0
14:16:10.599 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ] - Assembled message buffer = 01 07 00 13 1B 00 00 00 F0
14:16:10.599 [DEBUG] [b.z.i.protocol.ZWaveController:1164 ] - Process Message = 01 07 00 13 1B 00 00 00 F0
14:16:10.600 [DEBUG] [b.z.i.protocol.ZWaveController:192 ] - Message: class = SendData (0x13), type = Request (0x00), payload = 1B 00
14:16:10.600 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 5: SendData Request. CallBack ID = 27, Status = Transmission complete and ACK received(0)
14:16:10.601 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 05 02 84 08
14:16:10.601 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 1B 00
14:16:10.601 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false
14:16:10.601 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
14:16:10.601 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
14:16:10.602 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
14:16:10.602 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 5: Node advancer - VERSION: Transaction complete (SendData:Request) success(true)
14:16:10.602 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 5: Node advancer - checking initialisation queue. Queue size 2.
14:16:10.602 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 5: Went to sleep
14:16:10.602 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 5: Is sleeping
14:16:10.603 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 5: Response processed after 22ms/58ms.
14:16:10.603 [DEBUG] [WaveController$ZWaveSendThread:1211 ] - Took message from queue for sending. Queue length = 0
14:16:10.603 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 5: Putting message SendData in wakeup queue.`
