I have two homeseer ws200+ switches operating a fan and light in a half bath. Originally I set them up and everything worked. I had a rule on the fan that would turn it off 15 minutes after it was turned on.
Later on the fan switch stopped working. I turned off the circuit breaker and pulled them out and nothing was wrong. I then turn the breaker back on and the switches joined the network. So it thought everything was fine.
Recently I realized the fan wasn’t turning off. So I went into habpanel and the on/off switch wasnt able to turn the fan switch and light switch off and on anymore. The locally operated switches still worked but the zwave wasn’t controlling it. I then removed and readded the devices(fan and light) and while they added fine they weren’t controllable still.
The event logs show the on/off commands and the openhab log shows a command but it says “no ACK received”
2019-11-17 21:19:36.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:b8ae3f5d:node19:switch_binary --> ON [OnOffType]
2019-11-17 21:19:36.302 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 19: Creating new message for application command SWITCH_BINARY_SET
2019-11-17 21:19:36.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: SECURITY not supported
2019-11-17 21:19:36.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
2019-11-17 21:19:36.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Adding to device queue
2019-11-17 21:19:36.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Added 963 to queue - size 1
2019-11-17 21:19:36.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-11-17 21:19:36.302 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 13 03 25 01 FF 25 8D 85
2019-11-17 21:19:36.303 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 19: Sending REQUEST Message = 01 0A 00 13 13 03 25 01 FF 25 8D 85
2019-11-17 21:19:36.303 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-11-17 21:19:36.303 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 963: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 141
2019-11-17 21:19:36.303 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Polling intialised at 1800 seconds - start in 1500 milliseconds.
2019-11-17 21:19:36.304 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-11-17 21:19:36.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-11-17 21:19:36.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
It then does three retries and timesout. The crazy thing is the switches are 5 feet from two mains powered switches that work fine.
Any thoughts on what the problem is?
