OpenHABianPI
Sagemcom Router (Sagemcom 3686v2)
Three weeks ago everything was working well. From one device I could reach the http://openhabianpi:8080 and for other devices I just used myopenhab.
But two weeks agoI had to put on a “.local” in order to reach the dashboard also from this device: “http://openhabpian.local:8080”
I found this solution in a thread here.
One week ago I was not able to reach http://openhabian.local:8080" either and I had to start using the IP-adress.
The biggest problem with this as a lasting solution is that resources are not loaded in HabPanel due to xss-prevention / wrong host name:
vendor.js:195 Refused to load the stylesheet ‘http://openhabianpi.local:8080/static/layouts/example.css’ because it violates the following Content Security Policy directive: “style-src ‘self’ ‘unsafe-inline’”.
What are common reasons for hotname not working and how can I get this working again?
I tried to do a static host name binding from “openhabianpi” to the ip-adress, but this didn’t help. I thought this would be a sure thing solution. Why isn’t it?
