I use this rule(example) to do certain things like automating lights only at certain hours…
rule "example"
Item motion changed to ON
val Integer currentHour = now.getHour()
if ((8..19).contains(currentHour)){
bedroom.sendCommand(ON)
so i turn on the light only between 8am and 8 pm,but what if i want to turn it on between 8:30am and 8:45pm ?Can anyone give me an example to work with?
Add a virtual item and a rule with cron triggers to turn the virtual item on or off. Then your rule above just needs to check if the virtual item is on/off before firing the command.
It’s a little more indirect, but gives you more flexibility, since you can have multiple periods (e.g. 8:30am-10am and 7pm-8:45pm) and other triggers that aren’t based on time.
or instead of using time you could use the astro binding to have the light on only when it is dark.
To add to @rpwong Create a new switch item named like enable_lights
Then you can have a rule that runs on a cron trigger Time cron "0 30 8 ? * * *" 8:30am
rule "Enable Lights"
Time cron "0 30 8 ? * * *" or astro binding trigger
enable_lights.sendCommand(ON)
rule "Disable Lights"
Cron trigger or astro binding trigger
enable_lights.sendCommand(OFF)
rule "Motion detected turn light on if lights enabled "
if (enable_lights.state == ON){
i already use astro and iluminance readings from my aqara motion sensors to determin darkness night time for a more generic trigger.I just want to find out if there is a way to get hour and minutes in 2 values and use them for more detailed periods of time within the day…
You can. Work in minutes instead of hours. Set a variable to now and get the minutes and hours, multiply the hours by 60 and add to the minutes. Then do your compare in minutes.
