I am not sure how files, available on NAS as well as via DLNA shall be addressed.
Is it just that I fail in interpreting the correct path on the NAS or is there anything else to be checked?
Additionally I would like to understand how complete directories or playlists can be played.
Thanks for any hints.
Platform information:
Hardware: QNAP NAS
OS: Docker Container
Java Runtime Environment: which java platform is used and what version
Comparing the file:// access that also can be used in a browser to open a file that is available on a local or mapped drive I would try something like:
assumed that /MUSIK is a share that is mounted to the root. Yes, there are three /s.
Do you have a web server on your QNAP ? Then you could use the http protocol or try to create a playlist.
Thanks for the hint.
MUSIK is indeed a share folder on the NAS with the IP 192.168.1.21 and my default mp3-Player plays Test.mp3 when entering following in the explorer command line.
file://192.168.1.21/MUSIK/Test.mp3
Openhab does not succeed with any of the following commands
In PaperUI Control I can see that the Allplay State is briefly changing to “TRANSITIONING” and then to “STOPPED”. No Error Message in Openhab.log.
In my opinion the problem are access rights. The Openhab-Container runs on the NAS but with different IP and I have no glue how to grant Openhab access rights to the MUSIK share folder.
Actually I think anyway that access via DLNA would be better but there again I have no idea how to adress correctly.
On my Android-DLNA Player I find the file as specified in the DLNA server under “TS253B/Musik/Ordner/MUSIK/Test.mp3”
I tried following with and without Port without success. Then I stopped trial and error as I neither do not know whether the path “…/Musik/Ordner/…” is required nor if “.mp3” is needed.
I do not know the Allplay binding. In case you haven’t done yet increase the loglevel for the binding to see if more details will be logged: Logging | openHAB
how did you do that via explorer ? The explorer also is executed from a different IP address. Do you have to login with username and password ?
I accessed via my notebook where the NAS-network drives are connected and access codes are stored. So, no surprise that it worked.
But Openhab runs on the NAS in a Container with different IP address, so I assume it has no access rights and I do not know, how to grant OH or the Container access. I succeeded to SSH the QNAP and container but I do not want to play arround there as I do not want to crash my NAS.
With regard to logging I added to “org.ops4j.pax.logging.cfg” following lines but could not see any difference in “events.log” even after restarting the container. Obvisually I misunderstood the logging instructions.
