I’m using a Zigbee Binding and I’m trying to re-discover a device that I just removed. The device (an Aqara Wireless Switch without a Neutral line) has been discovered initially and I was able to control it successfully via the application. However, then I moved the switch to another room (further away from the controller) and it stopped working. So, I thought I should try to remove it and add it back again. Since then I tried all I could think of to make it visible again:
- I restarted the OH2 instance (version 2.4 on a Raspberry Pi 3) several times
- I removed all the items and links (using the smarthome:links / smarthome:items clear commands)
- I removed all the things related to this device in particular.
I don’t know what I could try anymore… the logs don’t show anything when I try to discover the device.
Anybody, any idea what am I doing wrong ?
Thank you !
