Is it better trying to retrieve the data with a xsl transformation or is it easier to get the value by a regex?
How can I step forward to develop either the xsl file or the regex step by step.? I need some kind of debugging. Any ideas what I can use best therefore?
That is a problem. XSLT won’t work unless the XML is well formed. I’d use Regex.
Move the transform to a Rule.
rule "Process PLC"
Item PLC_Raw receives update
val corrected = PLX_Raw.state.toString.replace("<br>", "<br/>")
val tagsAndVals = transform("XSLT", "plc.xslt", corrected)
// Process and post the tags and values to the appropriate Items
You didn’t provide any of your Items so I made one up. This is the Item that is bound to the HTTP binding but without any transformation.
Then the Item definition would look like:
PLC_Raw { http="plcCacheRaw:60000:REGEX((.*))" } // I don't know if you can totally skip the transformation so I use this noop REGEX transform
This is crazy overcomplicated. There is no need for a Python script. Besides, the HTTP binding cannot process file URLs, only HTTP URLs.
With one change to your Item and two lines of code added to a Rule you were going to have to write anyway to process the result of your XSLT transform you have solved your problem.
I could not provide an item, because I tried to learn a little bit xsl. Where I had to solve the nasty problem with the “/”.
After that I would have started with the items definitions
Your way to start just with an item (holding the raw webpage) seems to be indeed a lot easier.
This way makes the http binding in my eyes obsolet.
No. It is the HTTP binding that actually gets the HTML from the web server. The Item is bound to the HTTP binding. Without the HTTP binding you will get no data to process.
rule "Process AC40"
Item AC40_Raw receives update
val AC40corrected = AC40_Raw.state.toString.replace("<br>", "<br/>").state.toString.replace("<META HTTP-EQUIV="Refresh" CONTENT="30">", "")
val AC40_TL300E02B01 = transform("XSLT", "AC40_TL300E02B01.xsl", AC40corrected)
TL300E02B01.sendCommand (AC40_TL300E02B01 as DecimalType)
4 Create xsl-file AC40_TL300E02B01.xsl in rules folder
Should be String AC40_Raw { http="AC40CacheRaw:60000:REGEX((.*))" }
That was my mistake above. I left out the Item type.
You only call .state once. .state is a method on the Item. Once you call toString you are dealing with a String and there is no .state method. There is also no need to call toString again. Its already a Sring. Finally, you are dealing with just a String, so unless when you open this HTML in notepad is uses < instead of < you should use <. Finally, you need to escape double quotes within the String. Should be:
val AC40corrected = AC40_Raw.state.toString.replace("<br>", "<br/>").replace("<META HTTP-EQUIV=\"Refresh\" CONTENT=\"30\">", "")
AC40_TL300E02B01 is a String. You can’t just cast a String to a DecimalType. Assuming that this String is parsable (i.e. uses . for decimal instead of , and has no leading or trailing white space) you can just pass it as is to sendCommand.
This belongs in the transform folder.
I highly highly recommend using Designer. Most if not all of these errors would have been highlighted in red for you immediately as you type.
I’am using the designer, but nearly every line shows errors, so I don’t care a lot about this (I’am used to windows and not every error is really important)
is the only one which tell me that the cast from string to string is a little bit stupid so I left the cast and I get the messeage
But the field TL300E02B01 is defined as Number within the item-File.
what do I have to do to convert the string (“21.14428”) into a number?
I think it should convert by itself, as in the item definition the number format is specified as “%.1f”
My really big problem is at the moment that I have no idea how to debug.
In the karaf nothing is happening. The Temperatur is shown as “–”
I’am nearby, but still far away. (I’am also a little bit tired, so I’am going to bed now)
Every error you list is fatal. Your rule will not work with any one of these errors, let alone all of them. The only errors you can ignore are calls to add-on actions, Channel triggers, and references to Items defined in PaperUI. All other errors are real and must be corrected.
Indicates a problem on that line. Upon review I see you use “receives” instead of “received”.
The second error is telling you that you do not have an AC40_Raw Item. And as I pointed out above, there needs to be a String in front of that Item in the .Items file.
The third one which is actually two errors is probably caused by the second error. Once oh encountered that malformed Item definition for AC40_Raw, it stopped paying the file so your second item dues not exist either.
You don’t have to. Just pass the String to sendCommand and it will convert it to a number for you.
These are two completely different things. I don’t have the time to fully explain but suffice it to say you cannot convert a String to a Number or any other type using as.
Step one is making sure the are no errors down in Designer or confirming Designer is not showing real errors.
Then add logging to your rule to see where it fails.
rule "Process_AC40"
Item AC40_Raw received update
logInfo("Process_AC40","received update")
// val AC40corrected = AC40_Raw.state.toString.replace("<br>", "<br/>").replace("<META HTTP-EQUIV=\"Refresh\" CONTENT=\"30\">", "")
// val AC40_TL300E02B01 = transform("XSLT", "AC40_TL300E02B01.xsl", AC40corrected)
var AC40corrected = AC40_Raw.state.toString.replace("<br>", "<br/>").replace("<META HTTP-EQUIV=\"Refresh\" CONTENT=\"30\">", "")
var AC40_TL300E02B01 = transform("XSLT", "AC40_TL300E02B01.xsl", AC40corrected)
TL300E02B01.sendCommand (AC40_TL300E02B01)
the logInfo never comes.(even if I comment all the rest of the lines)
I still have the error on “AC40_Raw” where I get
“The method or field AC40_Raw is undefined”
I changed from val to var but there is no difference.
2017-03-13 01:55:11.559 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.OutOfMemoryError: Java heap space
at org.eclipse.osgi.container.ModuleDatabase$Persistence.readStringArray(ModuleDatabase.java:1381)
at org.eclipse.osgi.container.ModuleDatabase$Persistence.readMap(ModuleDatabase.java:1341)
at org.eclipse.osgi.container.ModuleDatabase$Persistence.readGenericInfo(ModuleDatabase.java:1280)
at org.eclipse.osgi.container.ModuleDatabase$Persistence.readModule(ModuleDatabase.java:1107)
at org.eclipse.osgi.container.ModuleDatabase$Persistence.load(ModuleDatabase.java:1015)
at org.eclipse.osgi.container.ModuleDatabase.load(ModuleDatabase.java:879)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:145)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:75)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:250)
at org.apache.karaf.main.Main.main(Main.java:175)
2017-03-13 01:55:19.799 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
Is there a way to get it run again? I only was playing with the http binding. I didn’t expect rebooting problems.
I’am running the version
login as: pi
pi@hab's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Mar 13 01:53:59 2017 from xxxxxxxxxxxx
########################## HAB #################### 5.15.160729 ####
## Ip = 192.168.1.xxx
## Release = Raspbian GNU/Linux 8 (jessie)
## Kernel = Linux 4.4.0-1-rpi2
## Platform = Raspberry Pi 2 Model B Rev 1.1
## Uptime = 0 day(s). 0:5:58
## CPU Usage = 27.02 % average CPU usage over 4 core(s)
## CPU Load = 1m: 1.04, 5m: 0.83, 15m: 0.39
## Memory = Free: 0.79 GB (84%), Used: 0.15 GB (16%), Total: 0.94 GB
## Swap = Free: 0.00 GB (0%), Used: 0.00 GB (100%), Total: 0.00 GB
## Root = Free: 26.09 GB (93%), Used: 1.69 GB (7%), Total: 29.29 GB
## Updates = 68 apt-get updates available.
## Sessions = 2 sessions
## Processes = 112 running processes of 7666 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.0 Build #547
[01:59:30] pi@HAB:~$
I now I have to update. As I have a very old version of openhabian it is better to do a complette reinstall.
Doubtful as I and hundreds of others are successfully using it.
Which means that AC40_Raw is never receiving updates.
Which is the root cause of the problem. This rule will never run as long as you see this error. The error says as far as OH is concerned AC40_Raw doesn’t exist. This points to some sort of syntax error in the .items file preventing OH from loading and parsing that file.
That is a REALLY old version of OH. There have been hundreds of bugs corrected and improvements made since build 547. This might even be before the first Beta release.
Save your /etc/openhab2 folder and upgrade. Without your being at least at the Release version (which is around build 790 I think) we will not be able to help much. There have been too many bugs fixed and changes made to begin to help.
Do not focus on getting this version running and focus on getting the release or 2.10 snapshot installed. I would start with a fresh openHABian given the problems you are seeing.
Do I have to add the binding in the addon.cfg File? Or is the file http.cfg enough information for the OH2 system to know what to do?
In my rules File I still have an error:
rule "Process AC40"
val AC40corrected = AC40_Raw.state.toString.replace("<br>", "<br/>").state.toString.replace("<META HTTP-EQUIV='Refresh' CONTENT='30>'", "")
I get the error:
What am I doing wrong?
Here comes the screenshot
Another question I’am concerning about is the second “toString.replace”
“<META HTTP-EQUIV=‘Refresh’ CONTENT=‘30>’”
There are two String in there which are surroundet by “” I changed that to apostrophes. Is that right?
The second error is the same as the first one. Only the variable name is changed.
You must install the binding by either installing it through PaperUI or adding it to addons.cfg.
If you don’t have the binding installed that could theoretically cause the AC40_Raw Item to not be successfully created which would account for the error.
2017-03-21 17:39:58.116 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'http' of item 'AC40_Raw' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig 'AC40CacheRaw:60000:REGEX((.*))' doesn't contain a valid binding configuration
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:50)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:268)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:102)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_112]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_112]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_112]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_112]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:655)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:371)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[32:org.apache.felix.scr:2.0.6]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:998)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.openhab.core.binding.internal.BindingConfigReaderFactory.registerDelegateService(BindingConfigReaderFactory.java:69)
at org.openhab.core.binding.internal.BindingConfigReaderFactory.addBindingConfigReader(BindingConfigReaderFactory.java:52)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:192)[32:org.apache.felix.scr:2.0.6]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:427)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.resolveBundles(ModuleContainer.java:1267)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.resolveBundles(FeaturesServiceImpl.java:1366)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:847)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_112]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
2017-03-21 17:39:58.278 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
No we are stepping forward. Without the crash I would not have noticed that addon.cfg. But after the reinstall I had some problems wiht that.
