How can I use to separated lines for the value and unit?
I have the problem that the value with the unit is too long to have both on the same line. I would like to have the value in one line and below the unit.
Up to now I have not found a way to do that but for sure there is a simple solution.
Thanks in advance
No, no simple one, but this one works.
Or you could adjust the font size.
If you show the widget yaml you are using, we can probably give you a more specific response.
sure:
- component: f7-col
              style:
                font-size: 13px
                font-weight: 800
                padding: 3px
            slots:
              default:
                - component: oh-label-card
                    action: analyzer
                    actionAnalyzerCoordSystem: time
                    actionAnalyzerItems: =[props.rainItem]
                    icon: '=Number(items[props.rainItem].state.replace("mm/h","").trim()) < 0.1 ?
                      "oh:classic:sun" :
                      < 5 ? "oh:classic:rain_low" :
                      < 15 ? "oh:classic:rain_strong" : "oh:classic:rain_heavy"'
                    iconColor: gray
                    item: =(props.rainItem)
                    label: =items[props.rainItem].state
                    trendGradient:
                      - "#f94144"
                      - "#42b983"
                    trendItem: =(props.rainItem)
                    trendStrokeWidth: 5
                    vertical: false
There are some technical reasons why this is a little harder with an oh-label-card than in some other instances. But, the way I would do this would be 3 steps:
  1. show only the number in the card label property
label: =items[props.rainItem].numericState
  1. add a css variable with the unit using the card’s style object
style:
  --card-unit: =`"${items[props.rainItem].unit}"`
  1. add a stylesheet to the card that appends the css variable on a new line after the other text in the label
stylesheet: >
  div > span::after {
    display: block;
    content: var(--card-unit);
with your very good idea I could solve it with this code:
label: =items[props.rainItem].state.replace("mm/h", "").trim()
                    style:
                    stylesheet: >
                      div > span::after {
                        display: block;
                        margin-top: 15px; /* Fügt Abstand zwischen Zahl und Einheit hinzu */
Thanks a lot!!
