I have two openhab instances, one is my main openHab System(basement) and the second is in my living room, where all other sensors are connected.
Is there a way to send all sensor data from my slave openHab to my main openHab?
I also have some switches which need to send the switch state to the main openHab.
My main openHab is running on my home server in the basement, where a few other VMs are running.
And i can’t establish any connection from my zigbee devices to the main openHab.
Between the main openHab and the slave openHab are two floors.
Hm that’s a good point, thanks i will check it out. Does it also will work with an docker openHab installation? My main openHab Server is running in docker.
