as i could see in:
there was some progress in the BSH Home Connect Binding.
How do i get the binding to my docker container ? What’s the best way ?`
Thanks in advance
Lars
as i could see in:
Thanks in advance
Lars
In the solution of Where to place extension .JAR file? it is described how to copy a binding/jar file into a docker container.
that means, that i have to compile the binding my self ?
The latest compiled jar file that I am able to find is this: https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.homeconnect/2.5.1-SNAPSHOT/
You can download the jar file and place it in the docker folder as described in the other post/thread.
thanks for that link! how do i search in jfrog ?
I am struggling with the jfrog web interface so I do not know how to use that one.
You can browse through the directories as they are open and list the content you may start at https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/
One possibility for the search would be google search like https://www.google.com/?q=homeconnect&as_sitesearch=openhab.jfrog.io/openhab/
Use the q parameter for your search while the as_sitesearch restricts the search to openhab.jfrog.io/openhab/
thank’s a lot
got it working… up to now, installation were really easy and smooth
