- Platform information: 4GB Ram virtual machine
- OS: _Ubuntu 22.04.1 LTS
- Java Runtime Environment: OpenJDK 64-Bit Server VM Zulu11.58+23-CA
- openHAB version: 3.1
Hi guys
sorry for my bad english.
I am in the process of creating my first widget and would like to replace a simple rule with it. The rule is built as follows:
Blockquoterule “tuer”
Item testschalter changed from OFF to ON
Turschloss_LockTargetLevel.sendCommand(‘Locked’)
My widget should perform this one action (as in the rule) after clicking on the button but unfortunately nothing happens. Do you have any idea what the problem is?
uid: Tür
tags: []
props:
parameters:
- description: Überschrift
label: title
required: false
type: TEXT
- context: item
description: Das Item welches den Zustand anzeigt
label: Zustand Item
required: false
type: TEXT
- context: item
description: Das Item zum steuerm
label: Schloss steuern
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 17, 2022, 5:30:49 PM
component: f7-card
title: =props.title
slots:
default:
- component: f7-card
class:
- text-align-center
title: =(items[props.Zustand_item].state)
slots: {}
- component: f7-row
slots:
default:
- component: f7-col
slots:
default:
- component: oh-button
action: command
actionItem: =(probs.schloss_steuern)
actionCommand: Locked
iconColor: green
iconF7: lock_fill
text: verschlossen
textColor: green
title: zuschliessen
- component: f7-col
slots:
default:
- component: f7-button
text: test 2
- component: f7-col
slots:
default:
text: test 3
I am very grateful for any tip.
Many greetings
Torsten
