2017-07-03 13:26:47.180 [INFO ] [est.sitemap.internal.SitemapResource]
2017-07-03 13:26:47.181 [WARN ] [eclipse.jetty.servlet.ServletHandler]
How can I find the full log path, when only the last chunk is visible in the logs?
that’s a very good question (I would like to know the answer also)
I usually google the stuff and sometimes find some reference in the eclipse project pages (not very sane method)
Edit: Maybe the Apache Felix Web Console has more info… I will check
You can change the layout of the Karaf console logger in [runtime]/userdata/etc/org.apache.karaf.log.cfg
. When you change the pattern from
pattern = %d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
to
pattern = %d{HH:mm:ss.SSS} [%-5.5p] [%c] - %m%n
it will log fully qualified class names (after restarting).
Similarly you can edit [runtime]/userdata/etc/org.ops4j.pax.logging.cfg
to change the logging format of the log files.
These patterns follow the log4j pattern layout.
