I have only had openHAB fully stop because:
- Memory leak in java
- Ran out of HDD space on device running openHAB due to camera recordings building up and not stored on a NAS.
- Ram drive or other space constrained ZRAM running fully out of space.
2 and 3 are outside of openhab and require monitoring and consideration when setting up how the system works.
Cause 1, I run monitoring on the system using the system doctor binding from the marketplace…
The red lines are where I did a system reboot when upgrading to the latest milestone, and the circled red area is where I got a memory leak from bad code I had written in a binding. The graph allows me to catch these issues before committing code to the project. After every update I just take a look at the graph over the next few days before I go more hands off on the system.
As others have mentioned, you could also be meaning if a single thing goes down, this happens when:
- Cloud service goes down that is required.
- Battery goes flat for wireless sensors.
- Bug in a binding not handling unexpected stuff occuring to bring the device back online again.
- Firmware update to a device breaks something that requires an update to a binding to fix.
Since things are going to break, I deliberately now design and choose gear so that they continue to work when openHAB goes down. I aim to have gear that is fully stand alone, yet can be augmented by openhab. I try to stay fully clear of a solution that totally rely’s on openHAB to be the full brain doing the heavy lifting.
Example of a bad way I don’t like where I use a wifi device to measure temp, and then another wifi device to heat with openhab doing all the logic. I choose to still do it knowing it will fail at some point…
An example of a system that I like is my watering system. It is fully stand alone to water the garden, it will automatically vary the watering amount based on weather forecasts. I use openHAB if the rain gauge reports enough rain has fallen, I can stop anymore watering for 3 days, and then stop the warning icon from showing up on my TV that warns us not to hang washing out on the days the grass gets watered. If I shutdown openHAB my grass still gets watered, but with openhab it is a nicer experience that saves water from being used, and our washing does not get drenched by the sprinklers.
