how do you tell if mqttActions.publishMQTT fails?
MQTT channel defined as follows:
Bridge mqtt:systemBroker:embedded-mqtt-broker "Moquette System Embedded MQTT Broker" @ "Family Room" [host="localhost", secure=false, retain=false, url="localhost:1883" ] {
Thing topic Generic_Moquette_MQTT_Thing "Generic Moquette MQTT Thing" @ "Family Room" {
Channels:
Type string : TableLamp_Color_Picker_MQTT "Table Lamp Color Picker MQTT Channel" [ stateTopic="tuya/3543376268c63ae3f978/25f1f8c229dacaa6/192.168.0.38/state", commandTopic="tuya/3543376268c63ae3f978/25f1f8c229dacaa6/192.168.0.38/color"]
Having an .items
Color TableLamp_Tuya_Smart_Color_Picker "Table Lamp Lumimen Bulb Color Picker [%s]" {channel="mqtt:topic:embedded-mqtt-broker:Generic_Moquette_MQTT_Thing:TableLamp_Color_Picker_MQTT"}
having a .sitemap as:
sitemap MangesHome label="Manges Home Automation" {
Frame label="Table Lamp Tuya Bulb"{
// turn the color bulb off
Switch item=TableLamp_Tuya_Smart_Color_Picker
// pick the color level to send to the color bulb via MQTT color Channel
Slider item=TableLamp_Tuya_Smart_Color_Picker minValue=0 maxValue=100 step=1
// color picked and sent via MQTT Color channel
Colorpicker item=TableLamp_Tuya_Smart_Color_Picker icon="colorpicker" sendFrequency=30000
Basically I am trying to control a color light bulb via an MQTT color channel
The implementation of the color channel works except every once in a while the command will fail and I see the response in openhab.log file.
Is there a way to get notified that the command failed before leaving the rule?
