I have a Dahua DH-SD22204T-GN (wired), which I basically only use in combination with Habpanel. I have it several years, the setup never worked reliable for more than a few days.
If I use Dahua sofware, it does work reliable. So I expect it has to do with how the IP camera binding retrieves the camera picture. Last week I updated to OH 3.1.0 and the problem seems worse now. When the IP camera binding is running for a couple of minutes, the camera becomes unreachable (HTTP access locks up, need to disconnect the camera power)
Poll time is set to 1000ms
Any experiences or other way to setup ? It seems to me polling the camera is not the best way, it the camera just can send a stream.
It always helps to use TRACE logging to get the reason why and use that to search the web forum, without some log output to help diagnose, the above is all I can offer.
Yes you can display a stream in habpanel, there is also a widget to help you do that found in the forum. If your on OH3.1 I would recommend you instead use the main UI widgets (also on forum) and not bother setting up habpanel as I would expect it to get phased out as the main UI is replacing it.
