I was actually referring to devices like the Qubino Flush 2 Relay which (in my installation) does not seem to be reporting the endpoints in its association updates. With my items defined as:
Switch Light_GF_Playroom_Ceiling_1 "Ceiling Light 1" { zwave="15:1:command=SWITCH_BINARY" }
Switch Light_GF_Playroom_Ceiling_2 "Ceiling Light 2" { zwave="15:2:command=SWITCH_BINARY" }
openHAB seems to be only receiving an update for endpoint 0, regardless of which physical switch is triggered, e.g.:
2016-01-28 08:59:38.601 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 15: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2016-01-28 08:59:38.601 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 15: No item bound for event, endpoint = 0, command class = BASIC, value = 0, ignoring.
2016-01-28 08:59:38.602 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2016-01-28 08:59:39.148 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 09 00 04 00 0F 03 25 03 00 D8
2016-01-28 08:59:39.148 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-01-28 08:59:39.149 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-01-28 08:59:39.149 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 0F 03 25 03 00 D8
2016-01-28 08:59:39.149 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 04 00 0F 03 25 03 00 D8
2016-01-28 08:59:39.150 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0F 03 25 03 00
2016-01-28 08:59:39.150 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 15: Application Command Request (ALIVE:DONE)
2016-01-28 08:59:39.150 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 15: Incoming command class SWITCH_BINARY
2016-01-28 08:59:39.150 [DEBUG] [.ZWaveBinarySwitchCommandClass:79 ]- Received Switch Binary Request for Node ID = 15
2016-01-28 08:59:39.151 [DEBUG] [.ZWaveBinarySwitchCommandClass:115 ]- NODE 15: Switch Binary report, value = 0x00
2016-01-28 08:59:39.151 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2016-01-28 08:59:39.151 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-01-28 08:59:39.151 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 15: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 0
2016-01-28 08:59:39.152 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 15: No item bound for event, endpoint = 0, command class = SWITCH_BINARY, value = 0, ignoring.
2016-01-28 08:59:39.152 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2016-01-28 08:59:39.703 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 10 00 04 00 0F 0A 32 02 21 34 00 00 00 00 00 00 CB
2016-01-28 08:59:39.703 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-01-28 08:59:39.704 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-01-28 08:59:39.704 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 10 00 04 00 0F 0A 32 02 21 34 00 00 00 00 00 00 CB
2016-01-28 08:59:39.705 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 10 00 04 00 0F 0A 32 02 21 34 00 00 00 00 00 00 CB
2016-01-28 08:59:39.705 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0F 0A 32 02 21 34 00 00 00 00 00 00
I have tried configuring the association for the individual switches:
(And similarly for the Q1 Switch Binary, Q2 basic/binary etc).
The reporting from the individual endpoints does not seem be working for me from this Qubino.
Thus in my earlier post, what I meant was that if there was a way to force a refresh of the physical device status from within an openHAB rule, I could then work out which switch was triggered.
You mentioned in a previous post that you are using the same Qubino relays. Are you getting the indivudual endpoint status updates?
