Thanks for your inputs. Added the file appender, and now I get a log file called Test.log as expected. However, my rules are still not triggering. The reason I got into this in the first place, is because I had started writing some rules, and nothing happened. Then I thought to reduce the rules to their most simple form, and still nothing is happening (i.e. no log entry appears). I already tried loginfo, didnât log anything either.
Do I need to do anything special to âactivateâ rules in OH2, besides copying them to /etc/openhab2/rules (Ubuntu, repo install) and making sure that there are no permissions problems (openhab, 766)? Btw, I did restart the OH2 service after every rule change.
No errors in events.log and none in opehhab.log either. I am running (actually testing) unstable, and just in case any bindings are getting into the way, I deactivated every single one of them - nothing is active anymore. Just the core system with a single rule, as stated above. My Test.log is zero bytes. Just in case I did something wrong in org.ops4j.pax.logging.cfg, here is my config:
I did not change anything else (should I have?). This a repo based install on Ubuntu 16.04. ZWave, OpenSprinkler and the DSC bindings I tested worked just fine. But without rules, I am not going anywhere in terms of automation. Anybody have an idea what the heck is going on? Or am I missing some vital point?
Just in case I missed something, this is the complete dump from my logs (I deleted them and this was created when I restarted the OH2 service):
events.log
2017-05-22 21:46:58.851 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode2ZW100MultiSensor6_SensorRelativeHumidity-zwave:device:f858f2b9:node2:sensor_relhumidity' has been added.
2017-05-22 21:46:58.863 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode5ZMNHBDFlush2Relays_Switch-zwave:device:f858f2b9:node5:switch_binary1' has been added.
2017-05-22 21:46:58.865 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode5ZMNHBDFlush2Relays_ElectricMeterWatts-zwave:device:f858f2b9:node5:meter_watts' has been added.
2017-05-22 21:46:58.867 [ItemChannelLinkAddedEvent ] - Link 'OpenSprinkler_Station01-opensprinkler:http:558dbb46:station01' has been added.
2017-05-22 21:46:58.869 [ItemChannelLinkAddedEvent ] - Link 'Keypad_KeypadReadyLED-dscalarm:keypad:4d883bb4:keypad:keypad_ready_led' has been added.
2017-05-22 21:46:58.870 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode2ZW100MultiSensor6_SensorTemperature-zwave:device:f858f2b9:node2:sensor_temperature' has been added.
2017-05-22 21:46:58.871 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode2ZW100MultiSensor6_SensorLuminance-zwave:device:f858f2b9:node2:sensor_luminance' has been added.
2017-05-22 21:46:58.873 [ItemChannelLinkAddedEvent ] - Link 'ZWaveNode2ZW100MultiSensor6_SensorMotion-zwave:device:f858f2b9:node2:sensor_binary' has been added.
2017-05-22 21:46:58.874 [ItemChannelLinkAddedEvent ] - Link 'Zone1_ZoneStatus-dscalarm:zone:4d883bb4:zone1:zone_status' has been added.
2017-05-22 21:46:59.020 [ThingAddedEvent ] - Thing 'dscalarm:keypad:4d883bb4:keypad' has been added.
2017-05-22 21:46:59.036 [ThingAddedEvent ] - Thing 'zwave:device:f858f2b9:node5' has been added.
2017-05-22 21:46:59.042 [ThingAddedEvent ] - Thing 'zwave:device:f858f2b9:node2' has been added.
2017-05-22 21:46:59.043 [ThingAddedEvent ] - Thing 'dscalarm:envisalink:4d883bb4' has been added.
2017-05-22 21:46:59.045 [ThingAddedEvent ] - Thing 'zwave:serial_zstick:f858f2b9' has been added.
2017-05-22 21:46:59.050 [ThingAddedEvent ] - Thing 'dscalarm:zone:4d883bb4:zone1' has been added.
2017-05-22 21:46:59.058 [ThingAddedEvent ] - Thing 'opensprinkler:http:558dbb46' has been added.
openhab.log
21:46:59.954 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-05-22 21:47:00.515 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-05-22 21:47:00.621 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-05-22 21:47:00.700 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-05-22 21:47:00.810 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
Man, I almost sunk into the ground when I read your post. Sure enough, I had named my rule .rule instead of .rules. My brain probably somehow thought that a folder called ârulesâ should contain multiple âruleâ files, never mind what the documentation says. In summary, my rule is processing now. Many thanks for your help, and very sorry for this basic mistake. And thanks to everyone for their support!
