I have a couple of the Trane TZEMT thermostats. To set a Hold or Resume the schedule requires a change to config parameter 132. This is inconvenient, as there’s no easy way to link this operation to the UI.
I’d like to add a channel to be able to set the Schedule Mode (Hold or Schedule). I wanted to confirm the correct way to do this before attempting to edit the database.
In the DB entry for this device (here), I would
- click the green + sign under the CONFIGURATION command class,
- add the Channel field
config_decimal
- add the Config field
parameter=132
- add the Label field
Schedule Mode
- save
I then would define an item linked to this channel, and would control the schedule mode by sending a 0 or a 1 to set the Hold or Run the Schedule, respectively.
Is this correct?
