@Frank_Apap, things are a new thing in Openhab 2. Before Openhab 2 there were only items. I recommend to use items whereever it is possible. If you add a philips HUE or a homematic gateway, you are forced to create things. However, you can link those things to items. I just wanted to let you know this.
For me it is easier to handle items in .items files. If possible, just use items. For example, with the HTTP binding. It could be, that you want to use a binding, which needs things. But like I said, you can(and should!) link those to items.
I also recommend to create those items in a .items file and not from the paper UI.
I will answer your question regarding the visual indicator for motion detectors, but please create a new topic in the right category, so if someone is searching for that problem as well, he knows where he could find it. The right place would be https://community.openhab.org/c/apps-services/habpanel
Thanks a bunch! I think Iāll focus on items for now and see if that makes things a little simpler. I created the new topic for the motion sensor, Representing a motion detector in HABPanel
And since youāve been a big help, I also have one other topic outstanding regarding integrating my other (non-zwave) devices, if/when you have time would love your thoughts:
I just started on OpenHAB and I am trying to add my veralite to it.
I am following the thread but the link to download the transformation that dayday1 shared with the group is no longer valid (https://www.file-upload.net/download-12447316/transform.zip.html).
Can somebody, please, share the file again?
*** WATCH OUT *** the download link for the transformation.zip file contains virus!
It downloads a transformationzip.iso file, which contains a transformationzip.exe file, that contains a trojan virus inside.
*** DO NOT DOWNLOAD OR CLICK ON THE .EXE FILE!!! ***
If somebody can send me a clean transformation.zip file, Iāll be very thankfull.
Please make sure you click the right download button. I mentioned this in my previous posts. The downloadsite is full of ads. I know that this is really bad, but I donāt know any other free hosters.
Sounds like you are yelling at me for spreading viruses. Please notice, that this is not the case. I simply uploaded a zip file there. Give me any other possibility to share a file and I will do my best to upload it there.
Hi dayday1! Iām not yelling at you, just warning other people to be really careful.
I use Hightail to send large file. As far as I know, there is a free account option.
BR!
