I am in the process of migrating to OH3 from OH2.x. I was able to setup my Aeotec Gen5 stick. Most of my Fibaro devices have been detected by the binding. However, I am struggling with my Flood Sensor as well as one Motion Sensor. I woke them up, replaced the battery etc. While trying to analyze problems, I realized that Habmin does not seem to be supported anymore. I am pretty sure the devices are included in my stick (they worked on OH 2.5).
Is there any way to view or change the configuration of the Z-Wave stick? There some hints in the forum with respect to the Flood sensor, e.g. setting the lifeline parameter. How can I do that? The thing configuration does not show that param.
The stick has no configuration that you can change (ie it has no configuration at all ).
Ok then my wording is either wrong or I most probably have a complete lack of understanding of how the Z-Wave network works. I always thought, that as part of the inclusion process, the stick stores at least information about the included devices.
Based on that I thought migrating from OH2.5 to OH3 would be easy in that respect… just plug in my old stick into the new Raspi with OH3, configure the bridge, add things and channels.
So what really puzzles me is that one of the motion sensors is not being detected while on the old setup (same stick) it works.
As mentioned earlier, probably it is related to the device not being woken up so that it can complete initialisation. The binding needs to completely rediscover all the data about devices, and for this battery devices that you are having trouble with will need to be woken up a number of times.
