How to ask a good question / Help Us Help You
Hi Guys @vzorglub @rlkoshak @H102 @5iver
A lot of you have helped me get OH2 up and running and over several hurdles on my ESP8266 boards and external sensors. I think I have got it down to about 30 steps with screenshots on adding a DHT11 with temperature and humidity readings for one room using MQTT 2.4. Once I get this all put together, I was wondering if I could have someone to look it over to make sure I’m taking too long to explain how to do this or errors in my instructions before I post to this section?
John Frankforther
Go ahead and post it and we can help you edit it. All of my tutorials are too long. I like to be very thorough. So don’t worry too much about that.
If you’d rather not have the edits be public (I think there is benefit to that as it shows how all of this stuff is an iterative process) you can send it as a pm.
If I have posted a question, received a response on suggestions and recommendations. What is the best way to follow up? I think if I reply to myself three times or more, I’ll get a little nag telling me I’m hogging the topic. I am taking the approach of editing my last entry to add information iteratively. In a current post, I replied, I updated once, and I updated again. Is this the proper approach? Will admins/contributors “see” these updates or will my updates and additional questions potentially go unnoticed, or at least for a longer period of time (e.g., days vs. hours)? Sure, I’m impatient, but I also want to know that I’m using the proper method that will receive warranted “attention”.
Thanks.
Mike
Don’t worry about the forum nags. Every time you add a reply we get a notification. Not for an edit. Several successive posts also show the incremental solution and that will help future readers.
Post away my friend. We can give feedback and you can then edit the original post. Or we can make it a wiki so that others can edit and add.
It looks like the HA folks have adopted this tutorial for posting a good question too. :wink: Don’t worry, they credited this post.
@vzorglub
Perhaps you also could mention these two interactive tutorials with discobot .
There is one for “new users” and one for “advanced users”. I did them both and they were really helpful. :slight_smile:
Hello @jhoney
How is this lat post relevant to this thread?
You usually start a new thread to post a question. You then are assured to be on-topic. Hopping on to somebody else’s thread is discouraged and usually considered rude.
Thus is the path to true wizardry!
:smiley:
@TRS-80 seconds the motion for “Rich, the King of the Forums”, and then…
Bump for @vzorglub… I think this would be very useful to get in front of new users. We should add something about code fences and anything else missing from this tutorial. FYI, the instructions in the OP of the tutorial topic are incorrect… PM @discobot with start tutorial or start advanced tutorial.
Here is the code fence link I usually use.
How to use code fences - Tutorials & Examples - openHAB Community
I have made the post a wiki, please feel free to edit
I will update the OP to include a reference to the tutorial, but is there a way to edit the tutorial to include a lesson for code fences?
I did some brief searching and it looks like customizing the overall flow is not yet implemented, or if it is implemented there is no documentation I can find for how to do it. Just about everything else can be customized by an admin (i.e. it would take Kai to add it). It might be possible to add the text or a link tutorial to one of the existing flows but I don’t see a way where we could add it and a test that the user did it right. It’s better than nothing though.
Anyone have a suggestion where in the flow it would be best to add it? Who is Discobot? has the easiest follow details for how to customize it that I was able to find.
If you want a real discobot tutorial about code fences it’s a bit tricky. Involves custom db query yada yada.
However we could “hijack” the already existing tutorial and add text about code fences.
See:
EDIT:
Oh well did not read properly. :roll_eyes:
I propose to add the code-fence tutorial with the quote tutorial
I’ve only asked a couple of questions and so far I’ve gotten some pretty quick and friendly help. I read this article about good questions and since I’m really new, but an old programmer, I’d like to make a few comments and ask a couple of questions of the leadership community.
My observations are much like Rich said, sometimes you get the right answer and sometimes the wrong answer. Having led R&D organizations that selected open source components and freeware and I can honestly say the money saved never approached the cost of the subsequent headaches over commercial solutions. The word hobby was used and that is what this is for me now and presumably many people, so it is OK.
My second comment comes from my past. Having inherited an IT department while leading R&D I soon realized that the massive amount of people needed to support our infrastructure was our own making! I initiated a plan to reduce the size from 25 to 5. My discoveries led me to the realization that poorly documented solutions forced an abundance of “help” needs (translate: easier to call). By sorting the high running rate requests and beefing up the documentation with examples and how-to’s, help calls dropped rapidly. It was also an eye opening exposer to my own product documentation leading to a reduction in my customer service desk.
Someone pointed out that helpdesk people get paid and this forum is free and voluntary, so the approach could never work. However, many volunteer entities accomplish significant results when coordinated.
It does lead me to a question I couldn’t find an answer too. I see there is Board but I didn’t find a steering committee for the distribution of information? From my brief browsing of the forum, there are clearly some experts. Sadly, I’ve seen some experts answering the same questions many times like my helpdesk example. They have even commented on the problem.
My question goes out to the few leaders. Has there ever been a concerted effort to “organize” the forum’s content that goes beyond individual contribution. One that might shorten the learning curve, coagulate information in digestible chunks, and thus reduce the post/reply to the exceptions, not the basics?
Has there ever been a consideration to “increase” the membership cost to support a “coordinator” of volunteers. To examine where the holes are and to initiate a voluntary “enhancement” of the website and the content.
I for one would be willingly to add my expertise to a finite initiative in that direction. I suspect, but can’t honestly speak for others, that they would be willing to document once rather than answer 10 times. I’m really not sure and don’t want to offend anyone. This is my first foray into open/free SW as a user, and maybe the general consensus is this is part of the fun of a hobby. I personally don’t think that because the posts are riddled with “help#$%#@”
Anyway, sorry for the long read. I’m just asking a couple of historians to maybe let me know what has transpired and/or if anyone has ever thought, or discussed something similar.
Thanks in advance
Cliff
Th official documentation written by the developers is very good but people do not look before they post their problem with no helpful information to solve.
There is also this little used area, based on the forum.
Thanks, didn’t know about the other how-tos. I can’t speak for the other people, I’ve spent weeks looking at the documentation. I’ll give you and example. There are numerous examples of cron statements. You can find them everywhere on the forum.
In fact, although the cron syntax is correct, I would prefer a more simple one: “0 0/5 * * * ?” //every 5 Minutes “0 1 0 * * ?” //daily at 12:01 am “0 1 0 1 * ?” //monthly at 01 12:01 am “0 2 0 1 1 ?” //yearly at 01-01 12:02 am year is optional, * is “don’t care”, ? is mandatory either on da…***
However, I was unable to get any cron job to work until I found out that there are “7” fields in the statement, not 6. This may be unique to openhabian, but it wasted countless hours for me. Even on the same page there are examples of 6 and 7. One may say the last is optional, but only the 7 would work for me.
