How to automate appliances using Raspberry pi GPIO pins directly in openhab
Here you will find some examples to directly control the GPIO pins of the raspberry that you have openhab installed on. A simple search for “GPIO” on the forum that you could have done yourself, would have brought that up:
If you want to use the GPIO pins of a raspberry that your openhab is not installed on, have a look here:
Once you can control the pins, all you need to do is hang a relay on them and start making rules to switch the relays on and off.
