Hello Guys…
What to put in the addons.cfg if i wanna let OH2 automatically install HabPanel?
Ive tested "Habpanel"
i get this in the debug log:
Failed installing 'openhab-ui-Habpanel': No matching features for openhab-ui-Habpanel/0.0.0
Hello Guys…
Just add a line in your addons.cfg like the following:
ui = habmin,habpanel
HOWEVER, I suspect that you are on an earlier version of openHAB 2 and you will need to update before the above will work.
After upgrading to build #580 i still can’t install…
the addons.cfg
# A comma-separated list of UIs to install (e.g. "basic,paper")
ui = basic,paper,habpanel,habmin
the error in log:
Failed installing 'openhab-ui-habpanel': No matching features for openhab-ui-habpanel/0.0.0
Can you install it via Paper UI?
Reason I ask is that I had an issue a few weeks ago with my addons.cfg
file, I still don’t know what was wrong but…
No it is still not listed in the paper UI… Also the problem with the Beta4
It is activated… has tried enable/disable… no success…
Sorry, but I am now at a loss to what is wrong. I am sure someone else will jump in soon.
Thanks so far
Hello!
I’m having a similar problem. I was using a snapshot (not sure of a build number) with HABPanel included in Paper UI. After upgrading to snapshot #574, HABPanel disappeared from Paper UI (both, main screen and Extensions -> UI). Maybe it was removed from the snapshot builds?
Best regards,
Davor
I’m on 574 and it is working fine, upgraded from 572 with the
this line in the /etc/openhab2/services/addons.cfg
ui = basic,classic,habmin,habpanel,paper
Previously i a problem with habpanel not showing up on the main x.x.x.x:8080 ui selecter webpage but that was matter of browser cache cleaning.
yes i could understand that it could be a cache problem if it just didn’t show up, and in paperui says it is installed… But here i can’t install from paperui and also the log file says it can’t download and install the habpanel…
Anyone has a solution? Or a link to download it manually
You should try the newest offline distribution, it doesn’t seem to have any problem.
If all else fails I suppose you could try downloading the .jar from https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/org.openhab.ui$org.openhab.ui.habpanel/ and drop it in your addons folder.
Had similar problems after updating from beta3 to b4 with apt. Solution for me: sudo rm -rf /var/lib/openhab2/cache/* (Taken from: openHAB 2.0 beta4 has been released!)
