Hi All,
is it possible at all to build a channel dynamically and make it read-only by using ChannelBuilder or something similar?
When I say read-only I mean something similar what you define a channel in xml file e.g.:
<channel-type id="rssi">
<item-type>Number</item-type>
<label>RSSI</label>
<description>Received signal strength indicator</description>
<state readOnly="true"></state>
</channel-type>
