If I set autoLinks=true in config file, all item/links are automatically created by ESH. But it uses channel label as item label. Is it possible to control this item label when items are created and persist new label
so that on restart it uses this label? May be it should use thing label as default label. This will help Alexa/Homekit to have unique and meaning full label for items.
regards,
Satish
