How to check if the notification is sent to myopenHAB Cloud
  • Platform information: RPI Zero
    • Hardware: CPUArchitecture/RAM/storage
    • OS: what OS is used and which version Openhabian
    • Java Runtime Environment: which java platform is used and what version Zulu Embedded 8.25.0.76; openjdk version “1.8.0_152”
    • openHAB version: openHAB 2.3.0-1
  • Issue of the topic:
    Please let me know if it is any possibility to check (inside the rules) if a notification was sent to myopenHAB Cloud. I want to be sure if the notification was received by the cloud and in case of a network disconnection or other issues, I want to resend that notification.
Wow! You are cutting it very fine @marian.tudor. Although the pizero will handle openHAB it won’t be able to handle much else. As you system grows you will need to upgrade your hardware.
Not that I know of
You might be able to use the http actions to pull down the notifications page on myopenhab.org and parse the HTML. I’ve never done it but it seems feasible.
Thank you for your answer.
I forgot to say that I’m using RPI Zero as a VPN server sometimes :-D.
Marian
I will try to follow you advice. Thank you !
