Hello All,
I am a beginner here, I have a question,
I am making a rule, where I want to compare if my state value is greater than 100 then publish some message, but it is publishing message even if it is less than 100:-
*** My item is defined as a string**
rule “airflow alert AF2021000001_d”
Item Airflow_AF2021000001_d changed
if (Airflow_AF2021000001_d.state.toString > 100) {
val mqttActions = getActions(“mqtt”,“mqtt:broker:MyMQTTBroker”)
mqttActions.publishMQTT(“xyz”, Airflow_AF2021000001_d.state)
Thank you.
