your rule turns LED on with every change of the motion sensor. This means, the LED is switched on by detection of movement AND is switched on by detection of no movement.
You need your rule to differentiate between turning on and off.
rule "Motion detected, turn LED on"
Item MotionSensor changed from OFF to ON
RaspiLED.sendCommand(ON)
rule "no Motion detected, turn LED off"
Item MotionSensor changed from ON to OFF
RaspiLED.sendCommand(OFF)
Sometimes you get in trouble with using sendCommand action, so it is advised to use the method of your item. (see sendCommand() Documentation)
Iām not sure how your PIR works, does it send an ON and OFF signal? First try the original rule you had, but that should only switch the LED ON and never OFF. Then you can try to change the rule to:
Item MotionSensor changed to ON
sendCommand(RaspiLED, ON)
if that doesnāt work you need to inspect the state of Motion sensor to see if it is producing ON/OFF states or some numerical value, you can do that in the console or by printing the state in the log.
if that worked, then you need to add code to your rule to turn the light OFF either based on a timer or based on the sensor switching back to its OFF state.
Are you sure you have wired the PIR correctly and that it is working?
If you want to inspect the state of an item you can do so by: telnet ip.address.of.openhb 5555
then openhab status MotionSensor
typing openhab will provide a list of available commands.
However, I think your PIR may not be wired properly or to the correct GPIO
By the way, I havenāt used the GPIO binding myself but did you follow the installation process and made sure your addons folder has the binding jar file? Can you verify with another item that the binding works (is RaspiLED also a gpio item?)?
After reading the binding documentation the states should be OPEN/CLOSED.
try to define your item like this: Contact MotionSensor { gpio="pin:18 activelow:yes" }
and try to inspect its state through the console
I thought i would look at this to see if it would solve my issue before posting a new topic, but im a bit stumped on the syntax, if appears that there is either a } missing or a ) in the wrong place. Im not sure either what || represents. Iām wondering if the rouge ) should be after timer == null
Hello @rlkoshak
I created a rule using your exemple but i received this error:
17:26:08.240 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 4 2020-07-10T17:25:44.564+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XFeatureCallImplCustom>.sendCommand(<XFeatureCallImplCustom>)
<null>.offTimer = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1205) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:861) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy163.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
17:26:08.272 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 4 2020-07-10T17:25:44.564+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.NullPointerException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
The rule is functional but i receive the error in Openhab console.
Can you help me to solve this ?
My rule is:
var Timer offTimer = null
rule "Handle PIR Events"
Item Motionsw1 received update
if(offTimer == null || offTimer.hasTerminated) {
LightA23.sendCommand(ON)
offTimer = createTimer(now.plusMinutes(1), [ |
LightA23.sendCommand(OFF)
offTimer = null
else {
offTimer.reschedule(now.plusMinutes(1))
