I hope to link the nest thermostat via ophenhab 1. X.
############################## Nest binding ###########################################
Data refresh interval in ms (optional, defaults to 60000)
nest:refresh=1000
HTTP request timeout in ms (optional, defaults to 10000)
nest:timeout=10000
the Nest Client ID needed to use the API, must be supplied
nest:client_id=a29130de-8274-44af-a0a4-ecec07233b8a
the Nest Client Secret needed to use the API, must be supplied
nest:client_secret=ZncfTL0DSavJ82ojCjajhNxkJ
the PIN code that Nest presented when you authorized the above client, must be supplied
nest:pin_code=2JTXXJLI
I saw “NEST APP” on the NEST thermostat .It gives me an ID of seven digits. I don’t know if this will help me.
