I am trying to do control fan speed in habpanel. But there is no any widget for fan speed controlling.Can anyone help me how to control fan speed like speed 1,2,3,4,5.Is there any possible in openhab2. please help me.
Thanks.
Do you have a binding ready for your fan so you sendComand to it?
If yes is will be very easy to do add UI for it in HabPanel.
No,which type of binding i have installed for fan speed controlling in habpanel.
Thanks.
If I understood you right, you haven’t configured the Fan in openHAB yet? So how is it controlled? The first step would be to create a Item which can receive commands for the fan. After you’ve got that item, you should think about the visualization.
You could create your own template, or you could just use the widget knob. Take a look on it, I think you could be happy with it.
I trying to build Eclipse Smart Home. But how to get distro for project run through CMD (Command Prompt) from Eclipse Smart Home. The project is successfully compiled without errors, but here i couldn’t see any distro folder.Please Help me…,
Thanks,
AMAR
