I tried to configure MongoDB persistence to store temperatures in the following way.
- I defined MongoDB’s url, db and collection name
$ grep mongodb configurations/openhab.cfg
mongodb:url=mongodb://127.0.0.1:27017
mongodb:database=openhab
mongodb:collection=openhab
- I defined a persistence model (copied from rrd4j.persist present in the demo)
$ cat configurations/persistence/mongodb.persist
Strategies {
everyMinute : “0 * * * * ?”
Items {
DemoSwitch,NoOfLights,Window_GF_Toilet,Heating* : strategy = everyChange, everyMinute, restoreOnStartup
Temperature*,Weather_Chart* : strategy = everyMinute, restoreOnStartup
- the rule is defined by:
rule “Update max and min temperatures”
Item Weather_Temperature changed or
Time cron “0 0 0 * * ?” or
System started
postUpdate(Weather_Temp_Max, Weather_Temperature.maximumSince(now.toDateMidnight, “mongodb”).state)
postUpdate(Weather_Temp_Min, Weather_Temperature.minimumSince(now.toDateMidnight, “mongodb”).state)
logInfo("Weather", "Temperature evolved of " + Weather_Temperature.deltaSince(now.minusMinutes(2)) + " degrees in 2 minutes.")
logInfo("Weather", "Midnight: " + now.toDateMidnight.toString)
The item Weather_Temperature gets temperature via a MQTT topic, the UI is properly updated, but I don’t have any values in the MongoDB instance.
At startup I have:
2015-08-18 16:09:51.835 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name ‘mongodb’
and while running I get several:
2015-08-18 16:11:00.013 [WARN ] [.m.i.MongoDBPersistenceService] - MongoDB not initialized
I tested MongoDB with its client and it works properly, I also tried to insert some test data and everything is ok. Why am I not able to “convince” OpenHab to insert data in MongoDB?
