I made a second rule to count the starts of today, but this rule is not working.
Error-Message from the log:
2017-01-10 09:05:19.581 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Kompressor Starts zählen 2': The name '<XMemberFeatureCallImplCustom>.state' cannot be resolved to an item or type.
Here is my rule:
rule "Kompressor Starts zählen 2"
Item HeatPump_state_compressor1 received update
postUpdate(HeatPump_counts_today, (HeatPump_compressor_count.deltaSince(now.toDateMidnight, "db4o").state as DecimalType)
I changed my rule a little bit and now it seems working…
Item HeatPump_compressor_count received update
var count_today = HeatPump_compressor_count.deltaSince(now.toDateMidnight, "db4o")
postUpdate(HeatPump_counts_today,count_today)
Is there a way to show values of last day? What other things are possible? Can you give me a link to a manual or table with all possible values for this two things (deltaSince, …) and (now.toDateMidnight, …)?
I try to do the same on my openhab2 but it doesn`t work. I got the following error message:
Rules:
2018-01-14 11:59:50.794 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Impulse z�hlen Waermepumpe': Could not cast NULL to org.eclipse.smarthome.core.library.types.DecimalType; line 6, column 35, length 42
rule "Impulse zählen Waermepumpe"
Item Imp_StrZ changed from OPEN to CLOSED
postUpdate(HeatPump_Stromzaehler, HeatPump_Stromzaehler.state as DecimalType + 1.0)
logInfo("Hinweise", "Zähler Wärmepumpe: " + HeatPump_Stromzaehler.state.toString )
Which line is “Line 6” of your rule? Is this the one with the logging? If yes, then try to remove the “.to.String” from the logging.
Your item is a number item and no string.
Is the shown item the right one? In your rule you write “Imp_StrZ” and your item is called “Imp_StZ” without the “r”. But it is called “Impuls Wasserzähler”, so is this the right one?
The error is caused by the fact that HeatPump_Stromzaehler is NULL (i.e. uninitialized). You can’t cast NULL to a DecimalType nor can you add 1.0 to NULL.
You may need to test for NULL before calling the postUpdate if the error persists.
just yesterday I discovered, that my onewire counter for my gas meter nulled for some reason.
Then I remembered to have set the real counter for some reason two months ago (at the start of heating Season - as I’m lucky to only need gas from mid-November till Mid-February). But whats more important here:
it works kind of - for some reason the S0counter gets nulled, and therefore my Approach to tell the Offset in a static variable was lost
So I changed the Approach - and as I use persistence, this one comes in Handy
I guess @Halloween, @Timo_Horn , you could adapt this one to your needs as well. This rule just counts the offset between the last two cycles and adds that one to the overall consumption counter.
in my script I use those items:
Sensoren_Leist_Gas => Actual Count of the S0-Reader (would be a compressor cycle)
Sensoren_Status_Gas => Overall consumption Counter (that one on my BK4 - would be your Counter)
as my BK4 Counts 1/100 of a m3 in one count, I have to calculate this.
I also had some troubles casting the right types for calculating and item updates. What I found out was quite confusing: Sensoren_Leist_Gas.sendCommand(value) didn’t update the value, only postUpdate did. As this one is an item without a binding, I am confused. Second one was Sensoren_Status_Gas.postUpdate(Sensoren_Status_Gas.previousState().state) didn’t work, I had to use a variable for the update-command for the argument. Same for the overall consumption, I had to use a variable for this…
So here’s my code, looks a bit ugly and rough.
rule "Gaszähler"
Item Sensoren_Leist_Gas changed
if (Sensoren_Leist_Gas != UNDEF) {
// calculate the Delta since the last update
var Number newCounter = (Sensoren_Leist_Gas.state as Number - previousState as Number)
// NULL abfragen
if (newCounter < 0) {
// This was my concern, if the S0 was nulled, use just the counter (it would be 1)
newCounter = Sensoren_Leist_Gas.state
if (Sensoren_Status_Gas.state == NULL) {
// I experienced even with .restoreOnStartup the state wasn't restored - so do it manually
var Number oldConsumption = Sensoren_Status_Gas.previousState().state
Sensoren_Status_Gas.postUpdate(oldConsumption)
Thread::sleep(10) // not sure, if needed, but somehow I suspected the script to be too fast sometimes
// now calculate the consumption and assign it to the counter
var Number newConsumption = newCounter/100
newConsumption += Sensoren_Status_Gas.state
Sensoren_Status_Gas.postUpdate(newConsumption)
this one works for now! just wanted to share with you guys.
